Hi!
My configuration is HAP ac as router with internet connection and CRS326 under routerOS as switch.
I’d like to connect them with a optic to free necessary port on HAP Ac
i ordered from FS.com @7m (23ft) Generic Compatible 10G SFP+ Active Optical Cable@ for connect router and a switch throu SFP and SFP+ port
Ininially nothing workes
I manually set connection speed to 1G in interfaces.
After that HAP AC have run SFP interface and i can see running interface and some outgoing TX packets
[admin@MikroTik] /interface ethernet> monitor sfp1
status: link-ok
auto-negotiation: disabled
rate: 1Gbps
full-duplex: yes
tx-flow-control: yes
rx-flow-control: yes
sfp-module-present: yes
sfp-rx-loss: no
sfp-type: SFP-or-SFP+
sfp-connector-type: copper-pigtail
sfp-link-length-copper: 7m
sfp-vendor-name: FiberStore
sfp-vendor-part-number: SFP-10G-AOC
sfp-vendor-revision: B1
sfp-vendor-serial: F171CO59138-1
sfp-manufacturing-date: 17-01-21
sfp-wavelength: 3072nm
eeprom-checksum: good
On other side, CRS326, i can see RX packets, but interface not running
status: no-link
sfp-rx-loss: yes
sfp-tx-fault: no
sfp-vendor-serial: F171CO59138-2
My question is: can i get working fiber connection between my devices?
