hAP ac WiFi empty Wireless not
In the GUI I have a WiFi and Wireless. The Wireless is pulated with the two wireless devices in the hAP ac the WiFi is empty.
Why is there a WiFi when it is empty and can I remove WiFi from list?
fw 7.19.4 (stable)
Check this:
Overview
The ‘WiFi’ configuration menu, introduced in RouterOS 7.13, is a RouterOS menu for managing Wi-Fi 5 wave2 and newer WiFi interfaces.
Devices with compatible radios also require either the ‘wifi-qcom-ac’ driver package (for 802.11ac chipsets) or the ‘wifi-qcom’ driver package for 802.11ax and newer chipsets.
The configuration menu used to be called ‘wifiwave2’ in RouterOS versions before 7.13, where it was a part of the ‘wifiwave2’ software package.
You might want to use it as capsman, to control other devices with wifi-drivers. You cannot remove it.
