Both 2.4 and 5 ghz radios are giving terrible performance.
I had only one enabled at a time when performing testing. No changes to factory configuration were made.
Wired speedtests show 30Mbs download and 5Mbs upload which is correct for my service.
Phone and wireless desktop show .08 - .11 Mbs download and 1.3Mbs upload.
Those devices were getting 10Mbs down and 5Mbs up using previous router.
I also ran iperf from a wired desktop to a wireless laptop and get 3Mbs when the wired is the server and 200-300 Kbs when the laptop is the server.
Upgraded to latest 6.38 RouterOS and 3.34 firmware with no changes.
I’ve tried changing just about every setting under the sun with little effect.
Any ideas before I send it back?
Appears this may be less of a wifi specific problem and more of a switch conflict issue. I decided to test with nothing plugged into the lan ports and got the full speed I was expecting. The moment I plugged in my tp link switch the wireless speed dropped again. Wired speed continues to be unaffected. Still looking for a cause but I think I’m a little closer.
downgraded to 6.37.3 with no change. When I shut off a wired machine that generates a lot of traffic the problem goes away so it does appear to be some kind of flooding but it’s only apparent with the wireless connection.
I do but not sure how that would prove anything. I was able to separate the wireless traffic on a different bridge group and it seems to have worked around the issue at least from the wireless side. I still believe there is an issue with traffic being flooded over the wireless network unnecessarily.
In talking to a friend that is more familiar with the Mikrotik gear it seems I was not aware that mulitcast traffic does not get filtered on the wireless interfaces by default. This would completely explain the issue I was having.
