Hi there,
I am running something like this:
│ │ 1 Gb/s│ │
│ Internet ├───────┤ RB4011 │
│ VLAN Trunk
│ 1 Gb/s
│ │ │ ether1 │ │ │
│ │ ┌────────┐ ┌─────────┐ │ │100 Mb/s ┌─────┐
│ │ │ wlan2g │ │ ether2 ├──┼─┼──────────┤ TV │
│ │ │ wlan5g │ │ ether3-5│ │ │
│ │ │ bridge-lan │ │
│ hAP ac² │ │
│802.11ac
│80 MHz 1S
│Android phone │
The hAP ac² is only used as wifi AP and access switch, all layer 3 stuff is on RB4011.
When the 100 Mb/s link to the TV is up, download speed from Internet to my Android phone is limited to ~70 Mb/s. As soon as I unplug the TV cable on ether2, download speed jumps back to 200+ Mb/s. Gigabit links on the same port have no such effect.
Current firmware is 6.48.5 long-term, but the same issue exists with all the previous long-term releases. I suspect that something strange is happening inside the switch chip, does anybody know a fix or a workaround for this?
For reference, this is the bridge and switch chip config:
add name=bridge-lan protocol-mode=none
add bridge=bridge-lan interface=ether1
add bridge=bridge-lan interface=ether2
add bridge=bridge-lan interface=ether3
add bridge=bridge-lan interface=ether4
add bridge=bridge-lan interface=ether5
set 0 vlan-mode=secure
set 1 default-vlan-id=10 vlan-mode=secure
set 2 default-vlan-id=10 vlan-mode=secure
set 3 default-vlan-id=10 vlan-mode=secure
set 4 default-vlan-id=10 vlan-mode=secure
set 5 vlan-mode=secure
add independent-learning=yes ports=ether1,ether2,ether3,ether4,ether5,switch1-cpu switch=switch1 vlan-id=10
add independent-learning=yes ports=ether1,switch1-cpu switch=switch1 vlan-id=99
add independent-learning=yes ports=ether1,switch1-cpu switch=switch1 vlan-id=20
Wifi interfaces are configured via capsman in local-forwarding mode:
# on hAP ac²
3 R ;;; managed by CAPsMAN
;;; channel: 5260/20-Ceee/ac/DP(17dBm), SSID: XXX, local forwarding
/interface wireless cap
set bridge=bridge-lan caps-man-addresses=192.168.XXX certificate=request discovery-interfaces=vlan-mgmt enabled=yes interfaces=\
wlan2g,wlan5g lock-to-caps-man=yes static-virtual=yes
# Datapath on capsman@rb4011
/caps-man datapath
add client-to-client-forwarding=yes local-forwarding=yes name=private vlan-id=10 vlan-mode=use-tag
add client-to-client-forwarding=no local-forwarding=yes name=guest vlan-id=20 vlan-mode=use-tag
