Hi!
After the latest firmware update on my hap ac2 that my isp automatically did ive had low speeds in my 5ghz band, i suppose to have 200mbs of download and the wifi band poorly has 60mb, is someone having the same problem?
No. Maybe because we have a different ISP?
Please … if you want a helpful answer be very specific:
- Your hAP ac2 is upgraded to what RouterOS version ?
- When you connect to 5 GHz wifi, what is in the WLAN2 wifi status page and in the registration table about your connections. (TX rate, RX rate, TX/RX CCQ, Signal strength, Signal to noise), then we can see if you get at least 433Mbps as interface rate( , because that is what you need for 200 Mbps data speed), and eventually the reason why you do not get that interface rate.
- Other causes are related to air-time and interference, and need more info to investigate (Scan, Freq Usage, Snooper).
- Any “auto” or XX or XXXX setting in your wifi config (band, frequency) makes performance totally unpredictable. It can be different after every restart.
5 How do you measure your speeds? Is a wired ethernet connection 200 Mbps ?
No, Mine is working fine.
I get about 350mbs within 5 feet and 200mbs within 30ft from my hap ac2.
