I am trying to setup my hap unit as station to my isp router.
I can connect to the wifi, have internet behind hap but for some reason when I am trying to ping the device from a pc that is on the main network I cant.
The problem seems to be that mikrotik doesn’t respond on my arp requests and the arp cache of my main pc doesn’t have an entry for the hap.
Pinging 192.168.2.254 with 32 bytes of data:
Reply from 192.168.2.10: Destination host unreachable.
Reply from 192.168.2.10: Destination host unreachable.Ping statistics for 192.168.2.254:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Interface: 192.168.2.10 — 0x3
Internet Address Physical Address Type
192.168.2.1 8c-68-c8-e7-b3-62 dynamic
192.168.2.48 54-35-30-c6-c9-c9 dynamic
192.168.2.230 18-a6-f7-12-f7-c7 dynamic
192.168.2.231 00-21-b7-53-15-a8 dynamic
192.168.2.232 00-1f-3f-c3-e5-90 dynamic
192.168.2.255 ff-ff-ff-ff-ff-ff static
224.0.0.22 01-00-5e-00-00-16 static
224.0.0.251 01-00-5e-00-00-fb static
224.0.0.252 01-00-5e-00-00-fc static
239.255.102.18 01-00-5e-7f-66-12 static
239.255.255.250 01-00-5e-7f-ff-fa static
Same time my main gateway can ping hap
PING 192.168.2.254 (192.168.2.254): 56 data bytes
Reply from 192.168.2.254: bytes=56 ttl=64 time=1.4ms seq=0
Reply from 192.168.2.254: bytes=56 ttl=64 time=1.6ms seq=1
Reply from 192.168.2.254: bytes=56 ttl=64 time=1.4ms seq=2
Reply from 192.168.2.254: bytes=56 ttl=64 time=1.4ms seq=3— 192.168.2.254 ping statistics —
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 1.4/1.4/1.6 ms
Its arp table has an entry for the hap
192.168.2.254 48:8f:5a:1f:90:42 Available LAN
If I ping from a hap my main pc then I can ping it back.
[admin@MikroTik] > export hide-sensitive
# aug/30/2020 19:39:52 by RouterOS 6.47.2
# software id = R3ZV-IZ4K
# model = RBD52G-5HacD2HnD
# serial number = CB380C19D06F
add admin-mac=48:8F:5A:1F:90:3D auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-1F9041 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=greece disabled=no distance=indoors frequency=auto installation=indoor ssid=Vodafone_5G-05374 wireless-protocol=nv2-nstreme-802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm
add name=dhcp ranges=192.168.88.2-192.168.88.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf disabled=yes interface=wlan2
add bridge=bridge interface=ether1
add interface=wlan2 list=WAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
add address=192.168.2.254/24 interface=wlan2 network=192.168.2.0
/ip dhcp-client
add interface=wlan2
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes servers=192.168.2.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,new,untracked
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add distance=1 gateway=192.168.2.1
/system clock
set time-zone-name=Europe/Athens
/tool mac-server
/tool mac-server mac-winbox
Any help would be great.
