I have just installed CAPs in my house. All of them work fine. However, as there is separated house for guests, and there is no cable, I have installed there hAP ac2. Wlan1 (2GHz) works a station (client) and wlan2 (5GHz) as a CAP. I was wondering if there is any chance to somehow create virtual wlan that would also work as AP under 2GHz under CAPsMAN control? Is there any way to achieve that?
There is an AP (BaseBox2 - connected to CAPsMAN) working on 2 GHz.There is a station device (hAP ac2) that has 2 radios: 2 (wlan1) & 5 (wlan2) GHz. Wlan1 is working as a station connected to AP and wlan2 is configured as CAP. This allows to use only 5 GHz wifi in the extended area. I was wondering if there is any way to connect to AP on 2 GHz but in the same time extend wifi with 5 but also 2 GHz.
you can use a virtual wlan interface to be the AP. then add this interface to your LAN bridge
for example, now I add wlan5 as a AP while I am using wlan1 as station
