Hello
i have hEX s with bridge on all ports 2-5 having on the ether5 connected hAP ac2 with bridge as well on all ports (poe in on ether1)
i tried to setup a dhcp on the bridge1 interface but it doesn’t get an IP on the interface.
i could access hAP ac2 with webfix only once I have ip on ether1
I dont know why too many i wonder myself i think it was the intial setup… i didnt create them myself
i do want to get, i used winbox to see the conf but i didnt see the bridge filter rule..
the dhcp works on the bridge, when I use the webfig to change it to be using bridge on WISP AP it changes automatically to router and adds the ip of ether1
I don’t know if it has anything to do with these bridges, but FYI: quickset can be used only for initial setup.
After you used it once or configured router manually you can never touch it again.
I mean literally NEVER.
And a piece of advice: better don’t use it at all.
ok now i understood what it was creating so much bridges, i did cleanup , removed unnecessary IPs from ether1
changed to CAP and configured CapsMan on heXs
its just great
i learnt now how to configure bridge properly
Basically it didnt fix the way to change on wisp ap to bridge (it was just changed to cap) which i am not sure that i know what is the difference.
Is there any guideness to find out more about WISP ap mode?
I assume that to set cap for one device currently is less inportant now, when i will add more cAPs it will be needed.
Also i found some loops while configurd the Capsman the network is disappearing from time to time because of bridge loop detected
ether5: bridge port received packet with own address as source address (48:8f:5a:52:aa:86), probably loop
You don’t need “wisp ap mode” you need “cap mode”.
If you want to find differences: reset to no config, try first, export, reset to no config, try second, export - you will have two configs that you can study in any text redactor.
Most likely loops are the result of adding cap interfaces to bridges on both sides, while you need to do it only on one side: either on caps, or on capsman.
in my end I had issue with the wifi network was in the bridge, I needed to add bridge to LAN and WAN only on hAP ac2
yes I want to understand which is preffere either “wisp ap mode” or cap mode
for now I wanted to study with capsman to know how can I build a roaming and add additional cAP in the future…
I think i will move back to “wisp ap” but I dont understand what the bridge mode in wisp ap means.
There is no such thing as “modes” outside of quickset.
Apart from “CAP mode” but that is not really the “mode” for the whole device, but rather just a configuration option.
I understand, so it just meters if i want to manage the wifi via caps or via dedicated device. I am looking what will be the best way to configure the wirless setings (like to avoid using b mode and to increase the 5ghz power) how do i do so in CapsMan
