HAP-ac2: Can't find Hide SSID Setting
Hi Folks,
Thanks for taking the time to read my post. I have Mikrotik HAP-ac2 router that I use for my home. It comes with two Wireless radios: 2.4GHz and 5GHz. However, I can’t find the setting to hide the SSID (or show it) from Winbox config when I open “Wireless > Wifi Interfaces > wlan-2” or “Wireless > Wifi Interfaces > wlan-5” dialog and look at the Wireless tab there. I can, however, find the “Hide SSID” checkbox for some Virtual wlans I have created under wlan-2.
Take a look at the picture https://imgur.com/a/5ycEuzr
Right now the SSIDs are hidden by default and I can’t see them unless I manually configure my devices to connect to these two wlans.
Can someone help me figure out where to Hide/Unhide SSIDs of the wlans on the main radios?
Zohaib
Click Advanced Mode
Thanks!
That was a dumb question :astonished:
