[hAP ac2] Can't get gigabit speed
Hello everyone, I received a new router today, connected it. With the old router I received Internet on my PC at a speed of about 1 Gbps, but with the new ac2 I get a maximum of 350 Mbps. What could be the problem? Please help…
Without having a look at your config and a picture of the complete network topology this device is being used in, hard to tell.
Drawing can be made on paper. Usually good enough. Make sure to indicate all different subnets.
Terminal:
/export file=anynameyouwish
Export and post between [__code] quotes, mask out serial number and public WAN IP.
Hi, sharing my exported file:
# feb/20/2023 17:55:58 by RouterOS 6.49.7
# software id = PJYJ-I6T6
# model = RBD52G-5HacD2HnD
# serial number = HDJ08H484BM
add admin-mac=48:A9:8A:1A:C2:E0 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-eC \
    country=ukraine disabled=no distance=indoors frequency=2452 installation=\
    indoor mode=ap-bridge ssid=MC1 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-eeeC country=ukraine disabled=no distance=indoors frequency=\
    5825 guard-interval=long installation=outdoor mode=ap-bridge ssid=MC1_5G \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=*** \
    wpa2-pre-shared-key=***
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
/tool mac-server
/tool mac-server mac-winbox
With a default setup using Fasttrack, the hAP ac2 is capable of close to Gigabit internet speed with NAT. Without NAT, it will switch over LAN at its rated speed no problem (computer to computer). It’s the WIFI that’s a bit disappointing. I would reset the device with the latest long term firmware and connect a single computer over ethernet for testing.
Anything that you add afterwards that requires the CPU will obviously reduce its available bandwidth.
yes you should be getting 1gig on hapac2…
I have a more powerful router and my ISP is 1gig, but I only see on speed test typically 960ish.
OP, How are you testing the speed?
