hap ac2 capsman, wifi has low performace
I have hap ac2 and hap ac, ac2 is used as capsman + cap, and acid used as ac. Both are running 6.42.5
If I enable local forward , the performance is quite good. 5G for ac2 is around 280Mbps, ac is around 220Mbps. If I disable local FW, let all throughput pass capsman (ac2), the 5G for ac2 is around 100Mbps, and I can see the one of the cpu core is fully running.
Does anyone experience same situation ? How about your 5G performance on ac2 when it’s acting capsman ?
vlan20 is for guest, vlan55 is for home
add name=br-vlan6
add name=br-vlan10
add name=br-vlan20
add name=br-vlan55
add bridge=br-vlan10 interface=ether3
add bridge=br-vlan10 interface=ether4
add bridge=br-vlan10 interface=ether5
add bridge=br-vlan55 interface=ecapsul
add bridge=br-vlan55 interface=ecapsul5
add bridge=br-vlan20 interface=guest
add bridge=br-vlan10 interface=vlan10
add bridge=br-vlan20 interface=vlan20
add bridge=br-vlan55 interface=vlan55
add address=192.168.10.254/24 interface=vlan10 network=192.168.10.0
add address=192.168.6.1/24 interface=ether2 network=192.168.6.0
add address=192.168.20.254/24 interface=vlan20 network=192.168.20.0
add address=192.168.55.254/24 interface=vlan55 network=192.168.55.0
/caps-man channel
/caps-man datapath
add bridge=br-vlan55 client-to-client-forwarding=yes comment=\
    "use local FW for better performance" name=datapath-ecapsul vlan-mode=\
    no-tag
add bridge=br-vlan20 client-to-client-forwarding=yes name=datapath-guest \
    vlan-mode=no-tag
    "use local FW for better performance" local-forwarding=yes name=\
    datapath-ecapsul5 vlan-mode=no-tag
    "use local FW for better performance" name=datapath-ecapsul_p
/caps-man rates
add basic="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48\
    Mbps,54Mbps" ht-basic-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,m\
    cs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mc\
    s-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,\
    mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-1\
    5,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" name=rate1 \
    supported="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbp\
    s,48Mbps,54Mbps" vht-basic-mcs=mcs0-9 vht-supported-mcs=mcs0-9
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
    name=ecapsul passphrase=xxxxx
    name=guest passphrase=xxxxxx
    name=ecapsul_p passphrase=xxxxx
/caps-man configuration
add channel=channel-2.4-4-Ce datapath=datapath-ecapsul mode=ap name=ecapsul \
    security=ecapsul ssid=ecapsul
add channel=channel-5-149-Ceee datapath=datapath-ecapsul5 mode=ap name=ecapsul5 \
    security=ecapsul ssid=ecapsul5
add channel=channel-2.4-1-Ce datapath=datapath-guest mode=ap name=guest \
    security=guest ssid=guest
add channel=2.4g-40mhz datapath=datapath-ecapsul mode=ap name=test security=
    ecapsul ssid=2ecapsul
add channel=channel-2.4-1-Ce datapath=datapath-ecapsul_p mode=ap name=ecapsu
    security=ecapsul_p ssid=ecapsul_p
add channel=channel-5-149-Ceee datapath=datapath-guest mode=ap name=guest5 \
    security=guest ssid=guest5
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=no interface=any \
    signal-range=-75..120 ssid-regexp=""
add action=reject allow-signal-out-of-range=10s disabled=no interface=any \
    ssid-regexp=""
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled comment="raido mac can identify each CAP"
    disabled=yes hw-supported-modes=gn master-configuration=ecapsul \
    name-format=prefix-identity name-prefix=2g radio-mac=E4:8D:XX:XX:0C:XX \
    slave-configurations=guest
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration
    ecapsul name-format=prefix-identity name-prefix=2g slave-configurations=
    guest
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration
    ecapsul5 name-format=prefix-identity name-prefix=5g
I trust if other cpu core can join the capsman and wifi, the performance could be better.
