Hi All,
I have a quite strange issue in my home network and I would ask your profession to find answers.
My home setup: Main router is a RB4011iGS+5HacQ2HnD-IN was running on 7.5 stable and a hap AC2 was managed by CAPSMAN with POE (idk if it is important).
- I updated RouterOS and the firmware on the main router to 7.6 stable, then I found in the log the AC2 is going down and up again repeatedly, constantly (approx once a minute).
- I downgraded the RouterOS and firmware back to 7.5 stable and restored configs from backup, but AC2 still behaves the same.
- I did reset on the main router to restore the default config, but didn’t fix it, even though I tried different eth ports on RB4011.
- I tried to reset the config (releasing reset button when it flashes), but winbox can find it in Neighbors..
- Last chance was to boot it in netinstall mode, but the router is not appearing in the list.. (Using eth1, static ip set correctly, firewall turned off, netinstall ran as admin, all other adapters disabled..)
Now, when the router is connected to my laptop with a direct cable in netinstall mode, I see in the Network adapters window it still disconnects and connects again. After it reconnects, the usr led is solid, so most probably it reboots, not just reconnecting.
Could you tell me what else I can try out to make my hap ac2 working again?
If it can be a hardware failure, do you think warranty would cover this? I bought this router just a few months ago, in May.
Thanks!
