hap ac2 din rail mount
Hi, didn’t anyone try to make DIN rail mounted stand for hap ac2?
or even tried to make own replacement stand, that will make easier to Create my own DIN rail stand for it.
hap ac 2 is small enough to place it into tiny boxes or cabinets, that’s why I want to try it out.
Haven’t tried but if you look for “din rail universal bracket” or “din rail universal mount”, you will find thousands of little plastic clips. Some of them might be easy to screw on existing hap ac^2 transparent stand. Then you clip your stand to din rail, clip your router on it and you are done :slight_smile:
I even did not imagine about existence of such thing! :slight_smile:
Thanks! I was looking for custom one, like the one for Raspberry I found earlier
by the way, I found universal bracket that may suit me: http://www.kronosrobotics.com/din-rail-mounting-brackets
