hAP AC2 & NetMetal AX
Hello everyone,
I have a couple of networks made up of 1 CAPsMAN hAP AC2 and some NetMetal AC2 Caps and they work fine.
Now I find myself in need of creating new networks and can no longer find NetMetal AC2 Caps.
I wanted to ask:
Can I use NetMetal AX Caps with a CAPsMAN hAP AC2?
What about the combination of NetMetal AC2 Caps with CAPsMAN hAP AX2?
What problems could I encounter?
The problem you’ll encounter is the existence of two Capsmans. One old one which is in the wireless winbox menu, the other new one is in the WiFi winbox menu. AX devices can only work with the new WiFi capsman. AC devices can work with either the old or the new one, but only one.
The settings of the new capsman are very different from the old one, watch the settings video. there is also in Ukrainian.
It is better to use only AX or only AC in one place
Thank you for your valuable information
