Hi all,
I am running one RB4011 as router (with wifi) and three hAP ac2’s (as wifi bridge).
Last Friday I noticed 7.14 (stable) was available as an update.
So I logged in to one of my hAP ac2’s via Winbox.
As usual, I went into Files and created a backup, which I also downloaded.
Then I went into System → Packages and Checked for Updates.
7.14 (stable) was available so I did a Download&Install.
The software downloaded and the hAP ac2 rebooted, but it never showed up in my Winbox again.
After half an hour of waiting for de device to show itself in Winbox again (doing a Refresh every few minutes), I unplugged the device and plugged it back in. But still no joy.
So I decided to do a reset.
I unplugged the device, pressed and held the rst/wps button and plugged it back in.
The pwr and usr led came on, and when the usr led started blinking, I release the rst/wps button.
After that, both pwr and usr led came on again, but the device still didn’t show up in Winbox.
So I hooked up the device directly to my laptop with a Cat6 UTP cable an powered on the device.
Again, the pwr and usr led come on, but it doesn’t show up in Winbox.
Occasionally, I see the usr led turning off and on again, and at the same time the ethernet interface on my laptop shows unplugged.
Also, it doesn’t matter on which port of the hAP ac2 I connect my cable (port 1 to 5). The result is the same as above.
So I decided to try a Netinstall as per these instructions:
https://wiki.mikrotik.com/wiki/Manual:Etherboot
and
https://wiki.mikrotik.com/wiki/Manual:Netinstall
But here’s where the instructions don’t line up with reality.
The hAP ac2 shows up in the Netinstall screen with status “ready”.
I select it the device, select the appropriate package I want to install, and hit install.
The device shows status “installing”, and after a short wait, it shows “ready” again.
The next step according to the manual is to select the “Reboot” option, but both Netinstall 7.13 and 7.14 don’t have this option!
So I unplug the device, wait a few seconds and plugged it back in.
But nothing happens…
Yes, the pwr and usr led come on, but it doesn’t show up in Winbox.
Again, I see the usr led turning off and on again, and at the same time the ethernet interface on my laptop shows unplugged.
And again, it doesn’t matter on which port of the hAP ac2 I connect my cable. The result is the same as above.
I tried both Netinstall version 7.13 and 7.14. All with the same results…
Now…
According to some posts I read on this forum, the 16Mb (actual 15.3MiB) could be the problem here.
On my other hAP ac2 devices, I have just one config backup of 251.8 KiB stored, resulting in 1% free flash space.
Apparently running 7.13 stable (with only Routeros and wireless packages) almost consumes all free space on the flash drive.
And the 7.14 package is allegedly ever larger than 7.13.
However, all posts mention that a Netinstall should do the trick, since a Netinstall reformats the flash drive and puts the new packages and firmware on the device.
In my case, a Netinstall does nothing.
So the question is, how to proceed now.
It would be a shame if my €80,- hAP ac2 would turn out to be a useless piece of plastic with some chips in it after an update.
