Hap ac2 poe
Good evening, can Hap ac2 powered in 250ft by it’s own passive Poe 24v ? Cable will use cat6.
http://poe-world.com/Calculator/
PoE in input Voltage 18-28 V
Voltage is OK but you should consider buying a 1.2A adapter.
Thanks,
I know voltage is ok, but are on limits
and generally I don’t like limits. Anyway, thanks again. :slight_smile:
