I’m a bit confused about the proper way of configuring vlans on HAP AC2:
Here is what I want:
WAN => eth1
VLAN10 => ether2,4
VLAN100 => ether3
VLAN150 =>ether5
Ok, now here is the part that I don’t get it
bridge menu : create bridge150=> assign ether5 to it
interfaces menu: create vlan150=> assign to interface bridge150
OR
interfaces menu: create vlan150 => assign to interface eth5 ?
++create the ip addresses + dhcp and assign to vlans .
anav
June 24, 2020, 2:56pm
2
Hm,
So, should I consider this setup as incorrect ?
[admin@MikroTik] > /interface vlan print
# NAME MTU ARP VLAN-ID INTERFACE
0 vlan10 1500 proxy-arp 10 ether5
1 vlan100 1500 proxy-arp 100 ether5
[admin@MikroTik] > ip dhcp-server pr
Flags: D - dynamic, X - disabled, I - invalid
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 dhcp-default bridge default-dhcp 1h
1 I hotspot ap-guest hotspot_pool1 30m
2 I dhcp1 vlan10 pool_vlan10 1h
3 I dhcp2 vlan100 pool_vlan100 1h
Where ether5 is trunk port to a netgear SW (caring vlans10+100)
sindy
June 24, 2020, 9:40pm
5
If you don’t need those VLANs anywhere else than on ether5, nor you need to bridge ether5 with any other port, there’s nothing wrong about that setup where the /interface vlan items are attached to ether5 directly.
