Hi to all,
I’m newbie about Mikrotik envorinment so I’m sorry about some mistakes in my config.
I bought an hAP ac2 and enjoying it as “station mode” for wlan1 (I connected it to an existing public wifi) and as “ap bridge” for wlan2, so I’m generating my own ssid (including NAT for my own devices so they can’t be discovered via the existing public wifi).
Everything is working and I’m really happy with that configuration except for 2 things:
-1 The most important, I have several devices including a Google Home. All the others devices working flawless but the Google Home has some issues that I can’t figure out. It is able to connect and work for some hours but at some point, it just disconnect from Mikrotik and the only way to solve is to reboot the Google Home.
-2 I can’t access Mikrotik control panel via wifi, I tried also via browser and WinBox and I can’t connect to it. Otherwise, If I plug an ethernet cable between ac2 and a laptop, I can access only via winbox.
1; What is in the LOG when the Google Home disconnects? What is in the wireless->registration when the Google Home is connected.
You may need to add the wireless logging (http://forum.mikrotik.com/t/wifi-limitations/146079/1 )
all depends on your config. Please share your configuration. In terminal, copy the output from command “/export hide-sensitive” or add here the *.rsc file made with “/export hide-sensitive file=anyfilename”
1- I just add wireless logging so we have to wait until it will disconnect.
This is what I see in wireless-registration (the blue one is the google home)
2-
# jan/18/2021 04:59:08 by RouterOS 6.47.3
# software id = 28MQ-8YX8
# model = RBD52G-5HacD2HnD
# serial number = B4A00C0C181B
add admin-mac=48:8F:5A:4E:F0:D6 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] auto-negotiation=no rx-flow-control=auto \
tx-flow-control=auto
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=public supplicant-identity=""
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
management-protection=allowed mode=dynamic-keys name=big \
allowed mode=dynamic-keys name=private supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no distance=indoors \
installation=indoor multicast-helper=disabled security-profile=public \
ssid=public station-roaming=enabled wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=5260 \
installation=indoor mode=ap-bridge multicast-helper=full \
security-profile=private ssid=MikroTik-4EF0DB station-roaming=enabled \
wps-mode=disabled
/ip hotspot profile
add name=dhcp_pool1 ranges=10.0.10.2-10.0.10.25
add address-pool=dhcp_pool1 disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool1 disabled=no interface=wlan2 lease-time=1d name=\
dhcp1
add address=10.0.10.1/8 comment=defconf interface=wlan2 network=10.0.0.0
/ip dhcp-client
add disabled=no interface=wlan1
add disabled=no interface=wlan2
add address=10.0.0.0/8 dns-server=10.0.10.1,8.8.8.8 gateway=10.0.10.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat src-address=10.0.0.0/8
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=Europe/Rome
/system logging
add topics=wireless
/tool mac-server
/tool mac-server mac-winbox
# jan/19/2021 12:29:23 by RouterOS 6.47.3
jan/18 04:40:56 system,error,critical router rebooted without proper shutdown, probably power outage
jan/18 04:41:06 bridge,info hardware offloading activated on bridge "bridge" ports: ether3,ether2,ether4,ether5
jan/18 04:41:06 wireless,info 18:E8:29:AA:36:7E@wlan1 established connection on 2437000, SSID private
jan/18 04:41:10 dhcp,info dhcp-client on wlan1 got IP address 10.10.10.26
jan/18 04:41:13 interface,info ether3 link up (speed 10M, full duplex)
jan/18 04:41:17 interface,info ether3 link down
jan/18 04:41:20 interface,info ether3 link up (speed 1G, full duplex)
jan/18 04:41:31 interface,info ether3 link down
jan/18 04:41:34 interface,info ether3 link up (speed 1G, full duplex)
jan/18 04:41:35 interface,info ether3 link down
jan/18 04:41:37 interface,info ether3 link up (speed 1G, full duplex)
jan/18 04:42:17 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -45
jan/18 04:42:41 wireless,info C8:E2:65:9F:40:93@wlan2: connected, signal strength -40
jan/18 04:43:01 wireless,info 18:82:8C:6D:8C:B2@wlan2: connected, signal strength -45
jan/18 04:43:23 wireless,info E4:42:A6:68:71:F3@wlan2: connected, signal strength -67
jan/18 04:44:25 wireless,info 00:F6:20:F2:89:00@wlan2: connected, signal strength -40
jan/18 04:44:26 dhcp,info dhcp1 assigned 10.0.10.3 to 00:F6:20:F2:89:00
jan/18 04:52:15 system,info,account user admin logged in from D0:50:99:81:DC:AF via winbox
jan/18 04:55:54 system,info log rule added by admin
jan/18 04:56:04 system,info log rule changed by admin
jan/18 04:56:37 system,info,account user admin logged in via local
jan/18 04:58:14 system,info,account user admin logged out via local
jan/18 04:58:30 system,info,account user admin logged in via local
jan/18 04:58:30 wireless,debug wlan1: start background scan
jan/18 04:58:37 wireless,debug wlan1: background scan complete, must select network
jan/18 04:58:37 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 04:58:37 wireless,debug wlan1: failed to select network
jan/18 04:58:37 wireless,debug wlan1: did not find better AP
jan/18 05:04:41 wireless,debug wlan2: 4C:63:71:9A:72:6E attempts to associate
jan/18 05:04:41 wireless,debug wlan2: 4C:63:71:9A:72:6E not in local ACL, by default accept
jan/18 05:04:41 wireless,info 4C:63:71:9A:72:6E@wlan2: connected, signal strength -65
jan/18 05:04:41 dhcp,info dhcp1 deassigned 10.0.10.6 from 4C:63:71:9A:72:6E
jan/18 05:04:41 dhcp,info dhcp1 assigned 10.0.10.6 to 4C:63:71:9A:72:6E
jan/18 05:08:37 wireless,debug wlan1: start background scan
jan/18 05:08:44 wireless,debug wlan1: background scan complete, must select network
jan/18 05:08:44 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 05:08:44 wireless,debug wlan1: failed to select network
jan/18 05:08:44 wireless,debug wlan1: did not find better AP
jan/18 05:16:50 wireless,debug wlan1: start background scan
jan/18 05:16:56 wireless,debug wlan1: background scan complete, must select network
jan/18 05:16:56 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 05:16:56 wireless,debug wlan1: failed to select network
jan/18 05:16:56 wireless,debug wlan1: did not find better AP
jan/18 05:23:50 wireless,debug wlan1: start background scan
jan/18 05:23:56 wireless,debug wlan1: background scan complete, must select network
jan/18 05:23:56 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 05:23:56 wireless,debug wlan1: did not find better AP
jan/18 05:27:22 wireless,info 4C:63:71:9A:72:6E@wlan2: disconnected, received deauth: sending station leaving (3)
jan/18 05:29:31 wireless,debug wlan1: start background scan
jan/18 05:29:38 wireless,debug wlan1: background scan complete, must select network
jan/18 05:29:38 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 05:29:38 wireless,debug wlan1: did not find better AP
jan/18 05:34:59 wireless,debug wlan1: start background scan
jan/18 05:35:05 wireless,debug wlan1: background scan complete, must select network
jan/18 05:35:05 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 05:35:05 wireless,debug wlan1: did not find better AP
jan/18 05:40:56 wireless,debug wlan1: start background scan
jan/18 05:41:02 wireless,debug wlan1: background scan complete, must select network
jan/18 05:41:02 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 05:41:02 wireless,debug wlan1: did not find better AP
jan/18 05:46:25 wireless,debug wlan1: start background scan
jan/18 05:46:32 wireless,debug wlan1: background scan complete, must select network
jan/18 05:46:32 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 05:46:32 wireless,debug wlan1: did not find better AP
jan/18 05:52:27 wireless,debug wlan1: start background scan
jan/18 05:52:33 wireless,debug wlan1: background scan complete, must select network
jan/18 05:52:33 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 05:52:33 wireless,debug wlan1: did not find better AP
jan/18 05:56:51 wireless,debug wlan2: 60:F2:62:E1:EB:19 attempts to associate
jan/18 05:56:51 wireless,debug wlan2: 60:F2:62:E1:EB:19 not in local ACL, by default accept
jan/18 05:56:51 wireless,info 60:F2:62:E1:EB:19@wlan2: connected, signal strength -54
jan/18 06:02:34 wireless,debug wlan1: start background scan
jan/18 06:02:40 wireless,debug wlan1: background scan complete, must select network
jan/18 06:02:40 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 06:02:40 wireless,debug wlan1: failed to select network
jan/18 06:02:40 wireless,debug wlan1: did not find better AP
jan/18 06:09:03 wireless,debug wlan1: start background scan
jan/18 06:09:09 wireless,debug wlan1: background scan complete, must select network
jan/18 06:09:09 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 06:09:09 wireless,debug wlan1: failed to select network
jan/18 06:09:09 wireless,debug wlan1: did not find better AP
jan/18 06:09:36 wireless,info 18:E8:29:AA:36:7E@wlan1: lost connection, received deauth: class 2 frame received (6)
jan/18 06:09:40 wireless,debug wlan1: must select network
jan/18 06:09:40 wireless,debug 80:2A:A8:AD:D9:8E: on 2412 AP: yes SSID public caps 0x431 rates 0xCCK:1-11 OFDM:6-54 BW:1x HT:0-15 basic 0xCCK:1-11 OFDM:6,12,24 MT: no
jan/18 06:09:40 wireless,debug B4:FB:E4:14:B1:AF: on 2412 AP: yes SSID public caps 0x431 rates 0xCCK:1-11 OFDM:6-54 BW:1x SGI:1x HT:0-23 basic 0xCCK:1-11 OFDM:6,12,24 MT: no
jan/18 06:09:40 wireless,debug 18:E8:29:AA:36:7E: on 2437 AP: yes SSID public caps 0x431 rates 0xCCK:1-11 OFDM:6-54 BW:1x SGI:1x HT:0-15 basic 0xCCK:1-11 OFDM:6,12,24 MT: no
jan/18 06:09:40 wireless,debug 2A:E8:29:AA:36:7E: on 2437 AP: yes SSID caps 0x431 rates 0xCCK:1-11 OFDM:6-54 BW:1x SGI:1x HT:0-15 basic 0xCCK:1-11 OFDM:6,12,24 MT: no
jan/18 06:09:40 wireless,debug B4:FB:E4:14:B2:7B: on 2462 AP: yes SSID public caps 0x431 rates 0xCCK:1-11 OFDM:6-54 BW:1x SGI:1x HT:0-23 basic 0xCCK:1-11 OFDM:6,12,24 MT: no
jan/18 06:09:40 wireless,debug C6:FB:E4:14:B2:7B: on 2462 AP: yes SSID caps 0x431 rates 0xCCK:1-11 OFDM:6-54 BW:1x SGI:1x HT:0-23 basic 0xCCK:1-11 OFDM:6,12,24 MT: no
jan/18 06:09:40 wireless,debug C6:FB:E4:14:B1:AF: on 2412 AP: yes SSID caps 0x431 rates 0xCCK:1-11 OFDM:6-54 BW:1x SGI:1x HT:0-23 basic 0xCCK:1-11 OFDM:6,12,24 MT: no
jan/18 06:09:40 wireless,debug 92:2A:A8:AD:D9:8E: on 2412 AP: yes SSID caps 0x431 rates 0xCCK:1-11 OFDM:6-54 BW:1x HT:0-15 basic 0xCCK:1-11 OFDM:6,12,24 MT: no
jan/18 06:09:40 wireless,debug 18:E8:29:5A:A8:A7: on 2462 AP: yes SSID public caps 0x431 rates 0xCCK:1-11 OFDM:6-54 BW:1x SGI:1x HT:0-15 basic 0xCCK:1-11 OFDM:6,12,24 MT: no
jan/18 06:09:40 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 06:09:41 wireless,info 18:E8:29:AA:36:7E@wlan1 established connection on 2437000, SSID public
jan/18 06:14:45 wireless,debug wlan1: start background scan
jan/18 06:14:52 wireless,debug wlan1: background scan complete, must select network
jan/18 06:14:52 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 06:14:52 wireless,debug wlan1: did not find better AP
jan/18 06:19:52 wireless,debug wlan1: start background scan
jan/18 06:19:59 wireless,debug wlan1: background scan complete, must select network
jan/18 06:19:59 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 06:19:59 wireless,debug wlan1: failed to select network
jan/18 06:19:59 wireless,debug wlan1: did not find better AP
jan/18 06:20:57 wireless,info E4:42:A6:68:71:F3@wlan2: disconnected, received deauth: unspecified (1)
jan/18 06:25:13 wireless,debug wlan1: start background scan
jan/18 06:25:20 wireless,debug wlan1: background scan complete, must select network
jan/18 06:25:20 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 06:25:20 wireless,debug wlan1: failed to select network
jan/18 06:25:20 wireless,debug wlan1: did not find better AP
jan/18 06:30:41 wireless,debug wlan1: start background scan
jan/18 06:30:48 wireless,debug wlan1: background scan complete, must select network
jan/18 06:30:48 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 06:30:48 wireless,debug wlan1: failed to select network
jan/18 06:30:48 wireless,debug wlan1: did not find better AP
jan/18 06:31:55 wireless,info 60:F2:62:E1:EB:19@wlan2: disconnected, received deauth: unspecified (1)
jan/18 06:31:58 wireless,debug wlan2: 60:F2:62:E1:EB:19 attempts to associate
jan/18 06:31:58 wireless,debug wlan2: 60:F2:62:E1:EB:19 not in local ACL, by default accept
jan/18 06:31:58 wireless,info 60:F2:62:E1:EB:19@wlan2: connected, signal strength -54
jan/18 06:36:47 wireless,debug wlan1: start background scan
jan/18 06:36:54 wireless,debug wlan1: background scan complete, must select network
jan/18 06:36:54 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 06:36:54 wireless,debug wlan1: did not find better AP
jan/18 06:46:54 wireless,debug wlan1: start background scan
jan/18 06:47:01 wireless,debug wlan1: background scan complete, must select network
jan/18 06:47:01 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 06:47:01 wireless,debug wlan1: failed to select network
jan/18 06:47:01 wireless,debug wlan1: did not find better AP
jan/18 06:54:53 system,info,account user admin logged out from D0:50:99:81:DC:AF via winbox
jan/18 06:54:53 system,info,account user admin logged out via local
jan/18 06:57:01 wireless,debug wlan1: start background scan
jan/18 06:57:08 wireless,debug wlan1: background scan complete, must select network
jan/18 06:57:08 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 06:57:08 wireless,debug wlan1: failed to select network
jan/18 06:57:08 wireless,debug wlan1: did not find better AP
jan/18 07:07:09 wireless,debug wlan1: start background scan
jan/18 07:07:15 wireless,debug wlan1: background scan complete, must select network
jan/18 07:07:15 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 07:07:15 wireless,debug wlan1: failed to select network
jan/18 07:07:15 wireless,debug wlan1: did not find better AP
jan/18 07:17:16 wireless,debug wlan1: start background scan
jan/18 07:17:23 wireless,debug wlan1: background scan complete, must select network
jan/18 07:17:23 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 07:17:23 wireless,debug wlan1: failed to select network
jan/18 07:17:23 wireless,debug wlan1: did not find better AP
jan/18 07:27:24 wireless,debug wlan1: start background scan
jan/18 07:27:30 wireless,debug wlan1: background scan complete, must select network
jan/18 07:27:30 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 07:27:30 wireless,debug wlan1: failed to select network
jan/18 07:27:30 wireless,debug wlan1: did not find better AP
jan/18 07:32:29 wireless,info C8:E2:65:9F:40:93@wlan2: disconnected, received deauth: unspecified (1)
jan/18 07:32:31 interface,info ether3 link down
jan/18 07:32:33 interface,info ether3 link up (speed 10M, full duplex)
jan/18 07:32:35 interface,info ether3 link down
jan/18 07:32:44 wireless,debug wlan2: 4C:3B:DF:1C:38:05 attempts to associate
jan/18 07:32:44 wireless,debug wlan2: 4C:3B:DF:1C:38:05 not in local ACL, by default accept
jan/18 07:32:44 wireless,info 4C:3B:DF:1C:38:05@wlan2: connected, signal strength -47
jan/18 07:32:45 dhcp,info dhcp1 deassigned 10.0.10.2 from 4C:3B:DF:1C:38:05
jan/18 07:32:45 dhcp,info dhcp1 assigned 10.0.10.2 to 4C:3B:DF:1C:38:05
jan/18 22:40:36 wireless,debug wlan1: start background scan
jan/18 22:40:43 wireless,debug wlan1: background scan complete, must select network
jan/18 22:40:43 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 22:40:43 wireless,debug wlan1: failed to select network
jan/18 22:40:43 wireless,debug wlan1: did not find better AP
jan/18 22:50:44 wireless,debug wlan1: start background scan
jan/18 22:50:50 wireless,debug wlan1: background scan complete, must select network
jan/18 22:50:50 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 22:50:50 wireless,debug wlan1: failed to select network
jan/18 22:50:50 wireless,debug wlan1: did not find better AP
jan/18 23:00:51 wireless,debug wlan1: start background scan
jan/18 23:00:58 wireless,debug wlan1: background scan complete, must select network
jan/18 23:00:58 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 23:00:58 wireless,debug wlan1: failed to select network
jan/18 23:00:58 wireless,debug wlan1: did not find better AP
jan/18 23:10:59 wireless,debug wlan1: start background scan
jan/18 23:11:05 wireless,debug wlan1: background scan complete, must select network
jan/18 23:11:05 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 23:11:05 wireless,debug wlan1: failed to select network
jan/18 23:11:05 wireless,debug wlan1: did not find better AP
jan/18 23:21:06 wireless,debug wlan1: start background scan
jan/18 23:21:13 wireless,debug wlan1: background scan complete, must select network
jan/18 23:21:13 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 23:21:13 wireless,debug wlan1: did not find better AP
jan/18 23:31:14 wireless,debug wlan1: start background scan
jan/18 23:31:20 wireless,debug wlan1: background scan complete, must select network
jan/18 23:31:20 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 23:31:20 wireless,debug wlan1: failed to select network
jan/18 23:31:20 wireless,debug wlan1: did not find better AP
jan/18 23:41:21 wireless,debug wlan1: start background scan
jan/18 23:41:28 wireless,debug wlan1: background scan complete, must select network
jan/18 23:41:28 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 23:41:28 wireless,debug wlan1: failed to select network
jan/18 23:41:28 wireless,debug wlan1: did not find better AP
jan/18 23:51:28 wireless,debug wlan1: start background scan
jan/18 23:51:35 wireless,debug wlan1: background scan complete, must select network
jan/18 23:51:35 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
jan/18 23:51:35 wireless,debug wlan1: failed to select network
jan/18 23:51:35 wireless,debug wlan1: did not find better AP
00:01:36 wireless,debug wlan1: start background scan
00:01:43 wireless,debug wlan1: background scan complete, must select network
00:01:43 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
00:01:43 wireless,debug wlan1: failed to select network
00:01:43 wireless,debug wlan1: did not find better AP
00:08:18 wireless,debug wlan2: E0:CC:F8:B3:0F:6D attempts to associate
00:08:18 wireless,info E0:CC:F8:B3:0F:6D@wlan2: reassociating
00:08:18 wireless,info E0:CC:F8:B3:0F:6D@wlan2: disconnected, ok
00:08:18 wireless,debug wlan2: E0:CC:F8:B3:0F:6D not in local ACL, by default accept
00:08:18 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -51
00:11:43 wireless,debug wlan1: start background scan
00:11:50 wireless,debug wlan1: background scan complete, must select network
00:11:50 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
00:11:50 wireless,debug wlan1: failed to select network
00:11:50 wireless,debug wlan1: did not find better AP
00:21:51 wireless,debug wlan1: start background scan
00:21:58 wireless,debug wlan1: background scan complete, must select network
00:21:58 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
00:21:58 wireless,debug wlan1: did not find better AP
00:31:58 wireless,debug wlan1: start background scan
00:32:05 wireless,debug wlan1: background scan complete, must select network
00:32:05 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
00:32:05 wireless,debug wlan1: did not find better AP
00:37:48 wireless,debug wlan1: start background scan
00:37:54 wireless,debug wlan1: background scan complete, must select network
00:37:54 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
00:37:54 wireless,debug wlan1: failed to select network
00:37:54 wireless,debug wlan1: did not find better AP
00:47:55 wireless,debug wlan1: start background scan
00:48:02 wireless,debug wlan1: background scan complete, must select network
00:48:02 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
00:48:02 wireless,debug wlan1: did not find better AP
00:58:02 wireless,debug wlan1: start background scan
00:58:09 wireless,debug wlan1: background scan complete, must select network
00:58:09 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
00:58:09 wireless,debug wlan1: failed to select network
00:58:09 wireless,debug wlan1: did not find better AP
01:08:10 wireless,debug wlan1: start background scan
01:08:17 wireless,debug wlan1: background scan complete, must select network
01:08:17 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
01:08:17 wireless,debug wlan1: failed to select network
01:08:17 wireless,debug wlan1: did not find better AP
01:18:17 wireless,debug wlan1: start background scan
01:18:24 wireless,debug wlan1: background scan complete, must select network
01:18:24 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
01:18:24 wireless,debug wlan1: did not find better AP
01:24:20 wireless,debug wlan1: start background scan
01:24:26 wireless,debug wlan1: background scan complete, must select network
01:24:26 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
01:24:26 wireless,debug wlan1: failed to select network
01:24:26 wireless,debug wlan1: did not find better AP
01:29:31 wireless,debug wlan1: start background scan
01:29:38 wireless,debug wlan1: background scan complete, must select network
01:29:38 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
01:29:38 wireless,debug wlan1: failed to select network
01:29:38 wireless,debug wlan1: did not find better AP
01:31:49 wireless,info E0:CC:F8:B3:0F:6D@wlan2: disconnected, received deauth: sending station leaving (3)
01:32:38 wireless,debug wlan2: E0:CC:F8:B3:0F:6D attempts to associate
01:32:38 wireless,debug wlan2: E0:CC:F8:B3:0F:6D not in local ACL, by default accept
01:32:38 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -56
01:39:38 wireless,debug wlan1: start background scan
01:39:45 wireless,debug wlan1: background scan complete, must select network
01:39:45 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
01:39:45 wireless,debug wlan1: did not find better AP
01:47:13 wireless,info E0:CC:F8:B3:0F:6D@wlan2: disconnected, received deauth: sending station leaving (3)
01:49:46 wireless,debug wlan1: start background scan
01:49:53 wireless,debug wlan1: background scan complete, must select network
01:49:53 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
01:49:53 wireless,debug wlan1: failed to select network
01:49:53 wireless,debug wlan1: did not find better AP
01:51:35 wireless,debug wlan2: E0:CC:F8:B3:0F:6D attempts to associate
01:51:35 wireless,debug wlan2: E0:CC:F8:B3:0F:6D not in local ACL, by default accept
01:51:35 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -60
01:59:15 wireless,info E0:CC:F8:B3:0F:6D@wlan2: disconnected, received deauth: sending station leaving (3)
01:59:53 wireless,debug wlan1: start background scan
02:00:00 wireless,debug wlan1: background scan complete, must select network
02:00:00 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
02:00:00 wireless,debug wlan1: did not find better AP
02:03:55 dhcp,info dhcp1 deassigned 10.0.10.4 from 18:82:8C:6D:8C:B2
02:03:55 wireless,info 18:82:8C:6D:8C:B2@wlan2: disconnected, received deauth: sending station leaving (3)
02:04:49 wireless,debug wlan2: 18:82:8C:6D:8C:B2 attempts to associate
02:04:49 wireless,debug wlan2: 18:82:8C:6D:8C:B2 not in local ACL, by default accept
02:04:49 wireless,info 18:82:8C:6D:8C:B2@wlan2: connected, signal strength -44
02:04:49 dhcp,info dhcp1 assigned 10.0.10.4 to 18:82:8C:6D:8C:B2
02:10:01 wireless,debug wlan1: start background scan
02:10:07 wireless,debug wlan1: background scan complete, must select network
02:10:07 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
02:10:07 wireless,debug wlan1: failed to select network
02:10:07 wireless,debug wlan1: did not find better AP
02:11:05 wireless,debug wlan2: E0:CC:F8:B3:0F:6D attempts to associate
02:11:05 wireless,debug wlan2: E0:CC:F8:B3:0F:6D not in local ACL, by default accept
02:11:05 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -59
02:14:25 wireless,info 60:F2:62:E1:EB:19@wlan2: disconnected, received deauth: unspecified (1)
02:14:25 wireless,debug wlan2: 60:F2:62:E1:EB:19 attempts to associate
02:14:25 wireless,debug wlan2: 60:F2:62:E1:EB:19 not in local ACL, by default accept
02:14:25 wireless,info 60:F2:62:E1:EB:19@wlan2: connected, signal strength -45
02:14:37 wireless,info 60:F2:62:E1:EB:19@wlan2: disconnected, received deauth: unspecified (1)
02:19:25 wireless,debug wlan2: 60:F2:62:E1:EB:19 attempts to associate
02:19:25 wireless,debug wlan2: 60:F2:62:E1:EB:19 not in local ACL, by default accept
02:19:25 wireless,info 60:F2:62:E1:EB:19@wlan2: connected, signal strength -45
02:19:37 wireless,info 60:F2:62:E1:EB:19@wlan2: disconnected, received deauth: unspecified (1)
02:20:08 wireless,debug wlan1: start background scan
02:20:15 wireless,debug wlan1: background scan complete, must select network
02:20:15 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
02:20:15 wireless,debug wlan1: did not find better AP
02:22:57 wireless,info 00:F6:20:F2:89:00@wlan2: disconnected, extensive data loss
02:30:16 wireless,debug wlan1: start background scan
02:30:22 wireless,debug wlan1: background scan complete, must select network
02:30:22 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
02:30:22 wireless,debug wlan1: failed to select network
02:30:22 wireless,debug wlan1: did not find better AP
02:40:23 wireless,debug wlan1: start background scan
02:40:30 wireless,debug wlan1: background scan complete, must select network
02:40:30 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
02:40:30 wireless,debug wlan1: failed to select network
02:40:30 wireless,debug wlan1: did not find better AP
02:50:31 wireless,debug wlan1: start background scan
02:50:37 wireless,debug wlan1: background scan complete, must select network
02:50:37 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
02:50:37 wireless,debug wlan1: failed to select network
02:50:37 wireless,debug wlan1: did not find better AP
03:00:38 wireless,debug wlan1: start background scan
03:00:45 wireless,debug wlan1: background scan complete, must select network
03:00:45 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
03:00:45 wireless,debug wlan1: failed to select network
03:00:45 wireless,debug wlan1: did not find better AP
03:10:46 wireless,debug wlan1: start background scan
03:10:52 wireless,debug wlan1: background scan complete, must select network
03:10:52 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
03:10:52 wireless,debug wlan1: failed to select network
03:10:52 wireless,debug wlan1: did not find better AP
03:20:53 wireless,debug wlan1: start background scan
03:21:00 wireless,debug wlan1: background scan complete, must select network
03:21:00 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
03:21:00 wireless,debug wlan1: failed to select network
03:21:00 wireless,debug wlan1: did not find better AP
03:31:01 wireless,debug wlan1: start background scan
03:31:07 wireless,debug wlan1: background scan complete, must select network
03:31:07 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
03:31:07 wireless,debug wlan1: failed to select network
03:31:07 wireless,debug wlan1: did not find better AP
03:41:08 wireless,debug wlan1: start background scan
03:41:15 wireless,debug wlan1: background scan complete, must select network
03:41:15 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
03:41:15 wireless,debug wlan1: failed to select network
03:41:15 wireless,debug wlan1: did not find better AP
03:51:15 wireless,debug wlan1: start background scan
03:51:22 wireless,debug wlan1: background scan complete, must select network
03:51:22 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
03:51:22 wireless,debug wlan1: failed to select network
03:51:22 wireless,debug wlan1: did not find better AP
04:01:23 wireless,debug wlan1: start background scan
04:01:30 wireless,debug wlan1: background scan complete, must select network
04:01:30 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
04:01:30 wireless,debug wlan1: failed to select network
04:01:30 wireless,debug wlan1: did not find better AP
04:11:30 wireless,debug wlan1: start background scan
04:11:37 wireless,debug wlan1: background scan complete, must select network
04:11:37 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
04:11:37 wireless,debug wlan1: failed to select network
04:11:37 wireless,debug wlan1: did not find better AP
04:21:38 wireless,debug wlan1: start background scan
04:21:45 wireless,debug wlan1: background scan complete, must select network
04:21:45 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
04:21:45 wireless,debug wlan1: failed to select network
04:21:45 wireless,debug wlan1: did not find better AP
04:31:45 wireless,debug wlan1: start background scan
04:31:52 wireless,debug wlan1: background scan complete, must select network
04:31:52 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
04:31:52 wireless,debug wlan1: failed to select network
04:31:52 wireless,debug wlan1: did not find better AP
04:41:53 wireless,debug wlan1: start background scan
04:41:59 wireless,debug wlan1: background scan complete, must select network
04:41:59 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
04:41:59 wireless,debug wlan1: did not find better AP
04:52:00 wireless,debug wlan1: start background scan
04:52:07 wireless,debug wlan1: background scan complete, must select network
04:52:07 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
04:52:07 wireless,debug wlan1: failed to select network
04:52:07 wireless,debug wlan1: did not find better AP
05:02:07 wireless,debug wlan1: start background scan
05:02:14 wireless,debug wlan1: background scan complete, must select network
05:02:14 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
05:02:14 wireless,debug wlan1: failed to select network
05:02:14 wireless,debug wlan1: did not find better AP
05:12:15 wireless,debug wlan1: start background scan
05:12:22 wireless,debug wlan1: background scan complete, must select network
05:12:22 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
05:12:22 wireless,debug wlan1: failed to select network
05:12:22 wireless,debug wlan1: did not find better AP
05:22:22 wireless,debug wlan1: start background scan
05:22:29 wireless,debug wlan1: background scan complete, must select network
05:22:29 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
05:22:29 wireless,debug wlan1: did not find better AP
05:32:30 wireless,debug wlan1: start background scan
05:32:37 wireless,debug wlan1: background scan complete, must select network
05:32:37 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
05:32:37 wireless,debug wlan1: did not find better AP
05:42:37 wireless,debug wlan1: start background scan
05:42:44 wireless,debug wlan1: background scan complete, must select network
05:42:44 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
05:42:44 wireless,debug wlan1: failed to select network
05:42:44 wireless,debug wlan1: did not find better AP
05:52:45 wireless,debug wlan1: start background scan
05:52:51 wireless,debug wlan1: background scan complete, must select network
05:52:51 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
05:52:51 wireless,debug wlan1: failed to select network
05:52:51 wireless,debug wlan1: did not find better AP
06:02:52 wireless,debug wlan1: start background scan
06:02:59 wireless,debug wlan1: background scan complete, must select network
06:02:59 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
06:02:59 wireless,debug wlan1: did not find better AP
06:05:16 wireless,info E0:CC:F8:B3:0F:6D@wlan2: disconnected, group key exchange timeout
06:13:00 wireless,debug wlan1: start background scan
06:13:06 wireless,debug wlan1: background scan complete, must select network
06:13:06 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
06:13:06 wireless,debug wlan1: failed to select network
06:13:06 wireless,debug wlan1: did not find better AP
06:23:07 wireless,debug wlan1: start background scan
06:23:14 wireless,debug wlan1: background scan complete, must select network
06:23:14 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
06:23:14 wireless,debug wlan1: failed to select network
06:23:14 wireless,debug wlan1: did not find better AP
06:27:03 wireless,debug wlan2: E0:CC:F8:B3:0F:6D attempts to associate
06:27:03 wireless,debug wlan2: E0:CC:F8:B3:0F:6D not in local ACL, by default accept
06:27:03 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -60
06:33:14 wireless,debug wlan1: start background scan
06:33:21 wireless,debug wlan1: background scan complete, must select network
06:33:21 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
06:33:21 wireless,debug wlan1: failed to select network
06:33:21 wireless,debug wlan1: did not find better AP
06:43:22 wireless,debug wlan1: start background scan
06:43:29 wireless,debug wlan1: background scan complete, must select network
06:43:29 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
06:43:29 wireless,debug wlan1: did not find better AP
06:53:29 wireless,debug wlan1: start background scan
06:53:36 wireless,debug wlan1: background scan complete, must select network
06:53:36 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
06:53:36 wireless,debug wlan1: failed to select network
06:53:36 wireless,debug wlan1: did not find better AP
07:03:37 wireless,debug wlan1: start background scan
07:03:44 wireless,debug wlan1: background scan complete, must select network
07:03:44 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
07:03:44 wireless,debug wlan1: failed to select network
07:03:44 wireless,debug wlan1: did not find better AP
07:13:44 wireless,debug wlan1: start background scan
07:13:51 wireless,debug wlan1: background scan complete, must select network
07:13:51 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
07:13:51 wireless,debug wlan1: failed to select network
07:13:51 wireless,debug wlan1: did not find better AP
07:23:52 wireless,debug wlan1: start background scan
07:23:58 wireless,debug wlan1: background scan complete, must select network
07:23:58 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
07:23:58 wireless,debug wlan1: failed to select network
07:23:58 wireless,debug wlan1: did not find better AP
07:33:59 wireless,debug wlan1: start background scan
07:34:06 wireless,debug wlan1: background scan complete, must select network
07:34:06 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
07:34:06 wireless,debug wlan1: failed to select network
07:34:06 wireless,debug wlan1: did not find better AP
07:44:07 wireless,debug wlan1: start background scan
07:44:13 wireless,debug wlan1: background scan complete, must select network
07:44:13 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
07:44:13 wireless,debug wlan1: failed to select network
07:44:13 wireless,debug wlan1: did not find better AP
07:54:14 wireless,debug wlan1: start background scan
07:54:21 wireless,debug wlan1: background scan complete, must select network
07:54:21 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
07:54:21 wireless,debug wlan1: did not find better AP
08:04:21 wireless,debug wlan1: start background scan
08:04:28 wireless,debug wlan1: background scan complete, must select network
08:04:28 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
08:04:28 wireless,debug wlan1: failed to select network
08:04:28 wireless,debug wlan1: did not find better AP
08:14:29 wireless,debug wlan1: start background scan
08:14:36 wireless,debug wlan1: background scan complete, must select network
08:14:36 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
08:14:36 wireless,debug wlan1: did not find better AP
08:24:36 wireless,debug wlan1: start background scan
08:24:43 wireless,debug wlan1: background scan complete, must select network
08:24:43 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
08:24:43 wireless,debug wlan1: failed to select network
08:24:43 wireless,debug wlan1: did not find better AP
08:34:45 wireless,debug wlan1: start background scan
08:34:52 wireless,debug wlan1: background scan complete, must select network
08:34:52 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
08:34:52 wireless,debug wlan1: failed to select network
08:34:52 wireless,debug wlan1: did not find better AP
08:44:52 wireless,debug wlan1: start background scan
08:44:59 wireless,debug wlan1: background scan complete, must select network
08:44:59 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
08:44:59 wireless,debug wlan1: failed to select network
08:44:59 wireless,debug wlan1: did not find better AP
08:55:00 wireless,debug wlan1: start background scan
08:55:06 wireless,debug wlan1: background scan complete, must select network
08:55:06 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
08:55:06 wireless,debug wlan1: failed to select network
08:55:06 wireless,debug wlan1: did not find better AP
09:05:07 wireless,debug wlan1: start background scan
09:05:14 wireless,debug wlan1: background scan complete, must select network
09:05:14 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
09:05:14 wireless,debug wlan1: failed to select network
09:05:14 wireless,debug wlan1: did not find better AP
09:07:40 wireless,debug wlan2: E4:42:A6:68:71:F3 attempts to associate
09:07:40 wireless,debug wlan2: E4:42:A6:68:71:F3 not in local ACL, by default accept
09:07:40 wireless,info E4:42:A6:68:71:F3@wlan2: connected, signal strength -69
09:15:15 wireless,debug wlan1: start background scan
09:15:21 wireless,debug wlan1: background scan complete, must select network
09:15:21 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
09:15:21 wireless,debug wlan1: failed to select network
09:15:21 wireless,debug wlan1: did not find better AP
09:25:22 wireless,debug wlan1: start background scan
09:25:29 wireless,debug wlan1: background scan complete, must select network
09:25:29 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
09:25:29 wireless,debug wlan1: failed to select network
09:25:29 wireless,debug wlan1: did not find better AP
09:35:17 wireless,info E0:CC:F8:B3:0F:6D@wlan2: disconnected, group key exchange timeout
09:35:29 wireless,debug wlan1: start background scan
09:35:36 wireless,debug wlan1: background scan complete, must select network
09:35:36 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
09:35:36 wireless,debug wlan1: failed to select network
09:35:36 wireless,debug wlan1: did not find better AP
09:45:17 wireless,debug wlan1: start background scan
09:45:24 wireless,debug wlan1: background scan complete, must select network
09:45:24 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
09:45:24 wireless,debug wlan1: did not find better AP
09:55:24 wireless,debug wlan1: start background scan
09:55:31 wireless,debug wlan1: background scan complete, must select network
09:55:31 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
09:55:31 wireless,debug wlan1: did not find better AP
10:02:14 wireless,debug wlan1: start background scan
10:02:20 wireless,debug wlan1: background scan complete, must select network
10:02:20 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:02:20 wireless,debug wlan1: did not find better AP
10:03:40 wireless,debug wlan2: E0:CC:F8:B3:0F:6D attempts to associate
10:03:40 wireless,debug wlan2: E0:CC:F8:B3:0F:6D not in local ACL, by default accept
10:03:40 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -84
10:07:21 wireless,debug wlan1: start background scan
10:07:28 wireless,debug wlan1: background scan complete, must select network
10:07:28 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:07:28 wireless,debug wlan1: did not find better AP
10:12:31 wireless,info E0:CC:F8:B3:0F:6D@wlan2: disconnected, extensive data loss
10:14:18 wireless,debug wlan1: start background scan
10:14:25 wireless,debug wlan1: background scan complete, must select network
10:14:25 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:14:25 wireless,debug wlan1: did not find better AP
10:20:07 wireless,debug wlan1: start background scan
10:20:14 wireless,debug wlan1: background scan complete, must select network
10:20:14 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:20:14 wireless,debug wlan1: did not find better AP
10:20:58 wireless,debug wlan2: E0:CC:F8:B3:0F:6D attempts to associate
10:20:58 wireless,debug wlan2: E0:CC:F8:B3:0F:6D not in local ACL, by default accept
10:20:58 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -60
10:25:15 wireless,debug wlan1: start background scan
10:25:22 wireless,debug wlan1: background scan complete, must select network
10:25:22 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:25:22 wireless,debug wlan1: failed to select network
10:25:22 wireless,debug wlan1: did not find better AP
10:30:23 wireless,debug wlan1: start background scan
10:30:29 wireless,debug wlan1: background scan complete, must select network
10:30:29 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:30:29 wireless,debug wlan1: did not find better AP
10:38:04 wireless,debug wlan1: start background scan
10:38:11 wireless,debug wlan1: background scan complete, must select network
10:38:11 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:38:11 wireless,debug wlan1: did not find better AP
10:43:11 wireless,debug wlan1: start background scan
10:43:18 wireless,debug wlan1: background scan complete, must select network
10:43:18 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:43:18 wireless,debug wlan1: did not find better AP
10:48:18 wireless,debug wlan1: start background scan
10:48:25 wireless,debug wlan1: background scan complete, must select network
10:48:25 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:48:25 wireless,debug wlan1: did not find better AP
10:53:25 wireless,debug wlan1: start background scan
10:53:32 wireless,debug wlan1: background scan complete, must select network
10:53:32 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:53:32 wireless,debug wlan1: did not find better AP
10:58:37 wireless,debug wlan1: start background scan
10:58:44 wireless,debug wlan1: background scan complete, must select network
10:58:44 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
10:58:44 wireless,debug wlan1: did not find better AP
11:02:38 wireless,info E0:CC:F8:B3:0F:6D@wlan2: disconnected, extensive data loss
11:02:48 wireless,debug wlan2: E0:CC:F8:B3:0F:6D attempts to associate
11:02:48 wireless,debug wlan2: E0:CC:F8:B3:0F:6D not in local ACL, by default accept
11:02:48 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -68
11:03:45 wireless,debug wlan1: start background scan
11:03:51 wireless,debug wlan1: background scan complete, must select network
11:03:51 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
11:03:51 wireless,debug wlan1: failed to select network
11:03:51 wireless,debug wlan1: did not find better AP
11:08:52 wireless,debug wlan1: start background scan
11:08:58 wireless,debug wlan1: background scan complete, must select network
11:08:58 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
11:08:58 wireless,debug wlan1: did not find better AP
11:14:33 wireless,debug wlan1: start background scan
11:14:40 wireless,debug wlan1: background scan complete, must select network
11:14:40 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
11:14:40 wireless,debug wlan1: did not find better AP
11:19:40 wireless,debug wlan1: start background scan
11:19:47 wireless,debug wlan1: background scan complete, must select network
11:19:47 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
11:19:47 wireless,debug wlan1: failed to select network
11:19:47 wireless,debug wlan1: did not find better AP
11:27:00 wireless,debug wlan1: start background scan
11:27:07 wireless,debug wlan1: background scan complete, must select network
11:27:07 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
11:27:07 wireless,debug wlan1: failed to select network
11:27:07 wireless,debug wlan1: did not find better AP
11:30:17 wireless,info E0:CC:F8:B3:0F:6D@wlan2: disconnected, group key exchange timeout
11:30:37 wireless,debug wlan2: E0:CC:F8:B3:0F:6D attempts to associate
11:30:37 wireless,debug wlan2: E0:CC:F8:B3:0F:6D not in local ACL, by default accept
11:30:37 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -63
11:32:08 wireless,debug wlan1: start background scan
11:32:15 wireless,debug wlan1: background scan complete, must select network
11:32:15 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
11:32:15 wireless,debug wlan1: failed to select network
11:32:15 wireless,debug wlan1: did not find better AP
11:35:17 wireless,info E0:CC:F8:B3:0F:6D@wlan2: disconnected, group key exchange timeout
11:37:57 wireless,debug wlan2: E0:CC:F8:B3:0F:6D attempts to associate
11:37:57 wireless,debug wlan2: E0:CC:F8:B3:0F:6D not in local ACL, by default accept
11:37:57 wireless,info E0:CC:F8:B3:0F:6D@wlan2: connected, signal strength -65
11:38:01 wireless,debug wlan1: start background scan
11:38:07 wireless,debug wlan1: background scan complete, must select network
11:38:07 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
11:38:07 wireless,debug wlan1: failed to select network
11:38:07 wireless,debug wlan1: did not find better AP
11:46:26 wireless,debug wlan1: start background scan
11:46:33 wireless,debug wlan1: background scan complete, must select network
11:46:33 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
11:46:33 wireless,debug wlan1: failed to select network
11:46:33 wireless,debug wlan1: did not find better AP
11:51:36 wireless,debug wlan1: start background scan
11:51:43 wireless,debug wlan1: background scan complete, must select network
11:51:43 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
11:51:43 wireless,debug wlan1: did not find better AP
11:57:55 wireless,debug wlan1: start background scan
11:58:02 wireless,debug wlan1: background scan complete, must select network
11:58:02 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
11:58:02 wireless,debug wlan1: failed to select network
11:58:02 wireless,debug wlan1: did not find better AP
12:03:32 wireless,debug wlan1: start background scan
12:03:39 wireless,debug wlan1: background scan complete, must select network
12:03:39 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
12:03:39 wireless,debug wlan1: did not find better AP
12:09:40 wireless,debug wlan1: start background scan
12:09:46 wireless,debug wlan1: background scan complete, must select network
12:09:46 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
12:09:46 wireless,debug wlan1: did not find better AP
12:14:47 wireless,debug wlan1: start background scan
12:14:53 wireless,debug wlan1: background scan complete, must select network
12:14:53 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
12:14:53 wireless,debug wlan1: did not find better AP
12:21:22 wireless,debug wlan1: start background scan
12:21:29 wireless,debug wlan1: background scan complete, must select network
12:21:29 wireless,debug wlan1: no network that satisfies connect-list, by default choose with strongest signal
12:21:29 wireless,debug wlan1: did not find better AP
12:22:50 wireless,debug wlan2: 60:F2:62:E1:EB:19 attempts to associate
12:22:50 wireless,debug wlan2: 60:F2:62:E1:EB:19 not in local ACL, by default accept
12:22:50 wireless,info 60:F2:62:E1:EB:19@wlan2: connected, signal strength -52
12:24:51 interface,info ether3 link up (speed 10M, full duplex)
12:24:53 wireless,info 60:F2:62:E1:EB:19@wlan2: disconnected, received deauth: unspecified (1)
12:24:54 interface,info ether3 link down
12:24:57 interface,info ether3 link up (speed 1G, full duplex)
12:24:58 wireless,debug wlan2: 60:F2:62:E1:EB:19 attempts to associate
12:24:58 wireless,debug wlan2: 60:F2:62:E1:EB:19 not in local ACL, by default accept
12:24:58 wireless,info 60:F2:62:E1:EB:19@wlan2: connected, signal strength -57
12:25:09 wireless,debug wlan2: C8:E2:65:9F:40:93 attempts to associate
12:25:09 wireless,debug wlan2: C8:E2:65:9F:40:93 not in local ACL, by default accept
12:25:09 wireless,info C8:E2:65:9F:40:93@wlan2: connected, signal strength -44
12:25:09 interface,info ether3 link down
12:25:10 wireless,info 60:F2:62:E1:EB:19@wlan2: disconnected, received deauth: unspecified (1)
12:25:15 interface,info ether3 link up (speed 1G, full duplex)
12:27:14 system,info,account user admin logged in from D0:50:99:81:DC:AF via winbox
12:27:15 system,info,account user admin logged in via local
12:29:00 system,info,account user admin logged in via local
Should be the line 306 useful?
First a general reaction to your config file. “All Roads lead to Rome” … there a many ways to config the MT router. There is not one perfect way, but let me tell what I would have done differently.
I extracted the relevant parts. Your config is OK, it are just some details.
WLAN1 is your station connection, WLAN2 your AP interface.
‘station-roaming’ is only meaningful if you have multiple AP’s to connect to with WLAN1. If not, then disable station roaming on WLAN1, it will avoid the repeated background scan. (as seen in the log)
Also the slow 802.11b protocol can be avoided by setting band=2GHz-g/n
WLAN2 is important for your Google Home connection. 5260MHz/XXXX is not very precise. The ‘XXXX’ could be replaced with ‘Ceee’ to indicate where the 5260MHz is in this wide band.
Signal is good, but using channels above 5500MHz will give you 7dBm more. Installation should be set to ‘any’ as MT sometimes mistaken blocks outdoor frequencies if set to ‘indoor’.
But choosing the right frequency is based on ‘Freq Usage’ and ‘Snooper’ scans of course.
You clearly did not add WLAN2 to the bridge, so it has it’s own DHCP server (OK!)
Interface list membership is important for access rules and for firewall rules.
I would have expected WLAN1 in the WAN list.
I would have expected bridge and WLAN2 in the LAN list (as WLAN2 is not added to the bridge)
Setting proper interface list membership will set acces levels (e.g. the control panel you mentioned) and would have made the default NAT rule working (NAT everything leaving via interfaces in the WAN list)
Without that you had to fabricate your own NAT rule
Combined with the registration table, (with RX and TX rate column too small to read all the information) there is not much to conclude.
The signal is strong, very strong, too strong (forget about increasing with 7 dBm). Distance must be made bigger, or the TX power of WLAN2 must be reduced.
Even with this strong signal not the full TX-rate is reached (too strong signal ?). Max could be 433Mbps for single stream. (433Mbps-80Mhz/1S/SGI)
To step down the 9 speed levels (till 6Mbps), and have “extensive data loss” because even that speed failed 21 times, either the Google Home must have stopped communicating, or a major wifi conflict must be in the air.
The other devices give no indication of a major wifi conflict, and the Google Home does not come back what always happens after such conflict.
Conclusion: “the Google Home stopped communication completely” is the most probable cause so far. There is no indication in the log nor registration why this happened in the Google Home.
Wow, what a support! Many thanks!
I followed your suggestions and I’m finally able to login via wlan (as you said, definitively the issue was in the interface list).
I also made other changes about freq etc.
About Google Home, at this point I think it’s issue it’s not related to MT. I can try to connect it to the public wifi and see what happens!
Tx/Rx was so strong becase I had to connect MT via ethernet (cause of the interface list, obv), but it’s tipically position it’s another one, I uploaded the tipical registration table.
Google Home issue seems to be solved! It never disconnects since last Thursday while, with my original config, it always disconnected in 20/24 hours.
Thank you!
