Hello everyone!
I faced a very strange situation and can't find any solution.
I have Hap AC2 connected to 100Mbit Internet provider and Qnap NAS connected to it by 1Gb port. For test purposes I used Macbook Pro 2018 and Samsung Galaxy Note 8.
I set up wireless network on my router and after some tests I got:
LAN 1Gbit -> Mikrotik -> SpeedTest -> 95Mbit up/down. OK
Wifi 5G from my Macbook -> Qnap NAS connected to LAN - > 400Mbit on Mac wifi adapter. About 200 Mbit on Mikrotik wifi interface. Also seems OK.
But! Wifi 5G from my Mac -> Speedtest -> 60Mbit download and 95 upload!
How???
Tests with my NAS shows that wifi was configured correctly. Router also works ok with cable tests.
Why I can't get full download speed from the Internet?
I tried firmwares 6.45.7 (the latest stable for today) and 6.44.6 (long term stable).
I made full reset of the router and configured it from zero. I tried to disable all firewall rules including Fasttrack. The results of Speedtest were the same.
Do you have any ideas why it can be?
There are my settings:
# nov/09/2019 20:47:57 by RouterOS 6.44.6
# software id = P1BB-0WFQ
# model = RBD52G-5HacD2HnD
add admin-mac=74:4D:28:E5:DF:DD auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-E5DFE1 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=ukraine disabled=no frequency=auto frequency-mode=regulatory-domain hw-protection-mode=rts-cts installation=indoor mode=ap-bridge ssid=MikroTik \
tx-power-mode=all-rates-fixed
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=12345
add bridge=bridge comment=defconf interface=wlan2
[*]/ip firewall export
nov/09/2019 20:49:24 by RouterOS 6.44.6
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface-list=WAN
