HAP Ac2 - WLAN1 as the WAN DHCP Client and WLAN2 as the AP ?
Hey Guys,
I want my WLAN1 to connect to Wireless at a cafe and obtain DHCP etc... then I would connect to WLAN2 as the AP.
I cannot seem to get WLAN1 to work, I get errors about it being a "Slave" when I try to configure WLAN1 for DHCP Client, and also I can connect to 2G Wireless but then it drops.
Can anyone help?
Thanks!!
mar/17/2022 15:46:29 by RouterOS 6.49.4
software id = ESBQ-D6KZ
model = RBD52G-5HacD2HnD
serial number = F66B0F49497F
add admin-mac=DC:2C:6E:62:01:4C auto-mac=no comment=defconf name=bridge
add name=protonvpn_blackhole protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] disabled=no frequency=auto ssid=Institute-2g
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=Hrvatska5g wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=Genki-Cellular supplicant-identity=MikroTik
/ip ipsec mode-config
add connection-mark=under_protonvpn name="ProtonVPN mode config" responder=no
/ip ipsec policy group
add name=ProtonVPN
/ip ipsec profile
add dh-group=modp4096,modp2048,modp1024 dpd-interval=disable-dpd enc-algorithm=aes-256 hash-algorithm=sha256 name="ProtonVPN profile"
/ip ipsec peer
add address=us.protonvpn.com exchange-mode=ike2 name="ProtonVPN server" profile="ProtonVPN profile"
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=0s name="ProtonVPN proposal" pfs-group=none
add name=dhcp ranges=192.168.89.10-192.168.89.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=wlan1 list=WAN
add address=192.168.89.1/24 comment=defconf interface=bridge network=192.168.89.0
/ip dhcp-client
add disabled=no
add address=192.168.89.0/24 comment=defconf dns-server=10.1.0.1 gateway=192.168.89.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.89.1 comment=defconf name=router.lan
/ip firewall address-list
add address=192.168.89.0/24 list=under_protonvpn
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=under_protonvpn passthrough=yes src-address-list=under_protonvpn
add action=mark-routing chain=prerouting new-routing-mark=protonvpn_blackhole passthrough=yes src-address-list=under_protonvpn
add action=change-mss chain=forward connection-mark=under_protonvpn new-mss=1360 passthrough=yes protocol=tcp tcp-flags=syn tcp-mss=!0-1375
/ip ipsec identity
add auth-method=eap certificate="ProtonVPN CA" eap-methods=eap-mschapv2 generate-policy=port-strict mode-config="ProtonVPN mode config" peer="ProtonVPN server" policy-template-group=ProtonVPN username=DtYVxn4rMF6ZG2il
/ip ipsec policy
add dst-address=0.0.0.0/0 group=ProtonVPN proposal="ProtonVPN proposal" src-address=0.0.0.0/0 template=yes
add disabled=yes distance=1 gateway=protonvpn_blackhole routing-mark=protonvpn_blackhole
add disabled=yes distance=1 gateway=192.168.88.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=America/Denver
/system identity
set name=Tardis
/tool mac-server
/tool mac-server mac-winbox
Basically you want to use the Device to GET WIFI on one WLAN (lets say the 2.5ghz WLAN) (like a client) and then use the 5ghz WLAN to distribute for your use in the apartment (like an AP).
Should be very doable. In essence one is using the 2.5 ghz as WIFI WAN.
Step 1 - Setup 2ghz wifi to connect properly with Establishment WIFI. SSID, password etc…
Step2 - Setup IP DHCP CLIENT interface=WLAN name, use default route yes,
Step3 - Setup Bridge on the device.
/ip dhcp-client
I think you want WLAN name here!!!
If you stated ADD Default route in IP DHCP client you dont need to add one here.
/tool mac-server
set allowed-interface-list**=LAN**
Set to NONE, the mac-server by itself is not encrypted and thus should not seen as a viable vehicle for router access.
Hi Anav,
Thank you for the help, it's working now but something is still wrong.
I cannot connect over HTTP to the router on 192.168.88.1 but I can ssh okay.
I think it must be Firewall related, I've tried rebooting. Does anything stick out to you?
/ip service print
NAME PORT ADDRESS CERTIFICATE
0 XI telnet 23
1 XI ftp 21
2 www 80
3 ssh 22
4 XI www-ssl 443 none
5 api 8728
6 winbox 8291
7 api-ssl 8729
/export hide-sensitive
mar/17/2022 18:39:00 by RouterOS 6.49.5
/interface wireless
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=Institute-2g supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=auto security-profile=Institute-2g ssid=Institute-2g
add name=ProtonVPN
/ip ipsec profile
/ip ipsec peer
/ip ipsec proposal
add interface=ether1 list=WAN
/ip dhcp-client
add disabled=no
add disabled=no interface=wlan1
add disabled=no interface=ether1
add address=192.168.89.0/24 comment=defconf dns-server=8.8.8.8 gateway=192.168.89.1 netmask=24
set allow-remote-requests=yes servers=10.7.7.1
/ip dns static
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
/ip firewall mangle
/ip ipsec identity
/ip ipsec policy
/ip service
/ip ssh
/system clock
/system identity
set name=Tardis
/tool mac-server
Not sure why you missed this on my first post??
/ip dhcp-client
Ether 1 is not providing you any WAN???
add interface=wlan1 list=WAN
Hi Anav,
I wanted to have ether1 as an alternative, so that if I physically connected ether1 to an Internet connection then it would act as the WAN, if unconnected then WLAN1 would act as the WAN.
But I deleted ether1 from the dhcp-client and also the interface list WAN and with a reboot I can access via HTTP again :slight_smile:
That fixed it, you are the MAN, thanks :slight_smile:
Updated config - for future forum readers.
/interface wireless
/interface wireless
add connection-mark=under_protonvpn name=“ProtonVPN mode config” responder=no
add name=ProtonVPN
/ip ipsec profile
add dh-group=modp4096,modp2048,modp1024 dpd-interval=disable-dpd enc-algorithm=aes-256 hash-algorithm=sha256 name=“ProtonVPN profile”
/ip ipsec peer
add address=us.protonvpn.com exchange-mode=ike2 name=“ProtonVPN server” profile=“ProtonVPN profile”
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=0s name=“ProtonVPN proposal” pfs-group=none
/ip dhcp-client
/ip dns static
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new disabled=yes
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
/ip firewall mangle
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
/ip ipsec identity
add auth-method=eap certificate=“ProtonVPN CA” eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=“ProtonVPN mode config” peer=
“ProtonVPN server” policy-template-group=ProtonVPN username=DtYVxn4rMF6ZG2il
/ip ipsec policy
add dst-address=0.0.0.0/0 group=ProtonVPN proposal=“ProtonVPN proposal” src-address=0.0.0.0/0 template=yes
/ip service
set winbox disabled=yes
/ip ssh
/system clock
/system identity
set name=Tardis
/tool mac-server
