HAP AC3 as CapsMan for 2x HAP AX2
I use HAP AC3 as main router without wifi. It does NAT and Capsman for 2x HAP AX2. I have installed wifi-qcom-AC on HAP AC3. Is this good combination when the HAP AC3 does capsman fo two AX device?
Thank you
You can safely uninstall wifi-qcom-ac on your AC3.
Very good combination, the wifi-qcom-ac is only beneficial if you need wireless on your hAP ac3. Otherwise, @infabo mentioned, you can uninstall it.
Guys, thank you for your answers.
I do care only about the right Capsman version. Do I use the correct Capsman at the moment with the wifi-qcom-ac? Is the actual Capsman with the wifi-qcom-ac capable of managing two HAP AX2?
Thank you
There is only one correct CAPsMAN version managing ax (wifi-qom) devices. This is part of RouterOS version 7.13 and up.
No need to install anything additional (like wifi-qcom-ac or wireless) for having CAPsMAN.
WiFi CAPsMAN is the correct term. Included in ROS base package 7.13+
