HAP AC3 Bridge HW Offload disabled
Im running RouterOS 7.4 Stable on hap ac3 RBD53iG-5HacD2HnD and i can’t get HW offload to work on bridge. I’m not running any VLAN filtering on that bridge.
[admin@PopCity-BRD] > interface/bridge/ export verbose
# sep/12/2022 12:40:53 by RouterOS 7.4.1
# software id = I1VK-XBCJ
# model = RBD53iG-5HacD2HnD
# serial number = F34E0FA0928B
add ageing-time=5m arp=enabled arp-timeout=auto auto-mac=yes dhcp-snooping=no disabled=no fast-forward=yes forward-delay=15s igmp-snooping=yes igmp-version=2 \
    last-member-interval=1s last-member-query-count=2 max-message-age=20s membership-interval=4m20s mld-version=1 mtu=auto multicast-querier=no \
    multicast-router=temporary-query name=Server priority=0x8000 protocol-mode=rstp querier-interval=4m15s query-interval=2m5s query-response-interval=10s \
    startup-query-count=2 startup-query-interval=31s250ms transmit-hold-count=6 vlan-filtering=no
add admin-mac=DC:2C:6E:23:A4:2A ageing-time=5m arp=enabled arp-timeout=auto auto-mac=no dhcp-snooping=no disabled=no fast-forward=yes forward-delay=15s \
    igmp-snooping=yes igmp-version=3 last-member-interval=1s last-member-query-count=2 max-message-age=20s membership-interval=4m20s mld-version=1 mtu=auto \
    multicast-querier=no multicast-router=temporary-query name=bridge priority=0x8000 protocol-mode=rstp querier-interval=4m15s query-interval=2m5s \
    query-response-interval=10s startup-query-count=2 startup-query-interval=31s250ms transmit-hold-count=6 vlan-filtering=no
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=defconf disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=\
    yes ingress-filtering=no interface=ether3 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 \
    pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes \
    ingress-filtering=no interface=ether4 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 \
    ingress-filtering=no interface=ether5 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 \
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=no \
    interface=wlan1 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no \
    interface=wlan2 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no \
add auto-isolate=no bpdu-guard=no bridge=Server broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=\
    yes interface=vlan-popesti internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=1 \
    yes interface=vlan-server internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=1 \
/interface bridge port-controller
# disabled
set bridge=none cascade-ports="" switch=none
/interface bridge port-extender
# disabled
set control-ports="" excluded-ports="" switch=none
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
Thanks.
Found, IGMP Snooping was configured on port…
