I have a problem with the LEDs of my hAP ac3 (RBD53iG-5HacD2HnD). In System LEDs, the following trigger is defined:
[admin@MikroTik] /system leds> print
Flags: X - disabled, * - default
# TYPE INTERFACE LEDS
0 * wireless-signal-strength wlan1 led1
led2
led3
led4
led5
I am connected to the router through wireless, but all of the LEDs are off and not showing the signal strength.
If instead wireless-signal-strength, I put “wireless status” or “interface activity”, all 5 leds are flashing simultaneously, so they are working. Why if I select “wireless signal strength”, they are all off and not showing anything?
Also, if I try to remove any entry, I receive the following error:
failure: can not remove preset leds
Why is that and how can I delete an already added entry?
