HAP AC3 LTE6 and wifiwave2
Hello!
As I know HAP AC3 (non LTE6 version) supports wifiwave2 package.
But HAP AC3 LTE6 - not.
But they are both having the same chip model - IPQ-4019.
So the question is what will be if I add wifiwave2 package to my HAP AC3 LTE6 ?
BTW, I am currently not using LTE6 modem on router.
Not enough space.
AC3 LTE only has 16Mb storage whereas AC3 has 128Mb.
(if you ask me, not a wise decision … hard to believe there would be a technical reason for that reduced space)
Check free resources on your device.
You can’t shoe-horn wifiwave2 package into that …
Thanks for an answer!
Oh yes, only 16M storage. Very sad. Dont think storage is expensive nowdays…
