[hap_ac3] pppoe connection very slow
hi,
actually I’ve a Vodafone internet connection with fttc technology.
In my infrastructure I have:
  • TP-LINK Archer VR1210v : as bridge modem
  • Mikrotik hap ac3 : as router
The really strange situation is: if I try to connect using PPPoE directly from TP-Link, Internet connection is quite good. if I use tplink+mikrotik connection is very slow.
Speedtest:
using mikrotik: https://www.speedtest.net/result/13213351429
using tp link: https://www.speedtest.net/result/13213399837
I’ve taken PPPoE parameters by this support page
https://www.vodafone.it/privati/supporto/assistenza-dispositivi/altri-dispositivi/modem-alternativo.html
My actual config on My ac3:
export.rsc (27.8 KB)
any help? what am I missing? I’m really newby in mikrotik world, sorry about that
Che export hai fatto?
troppi dettagli, non ci si capisce una mazza.
vlan-id=1048 ??? on doc are 1036…
use /export without verbose
vlan id is set on the tp link bridge interface to 1036
# may/29/2022 23:35:36 by RouterOS 7.2.3
# software id = PTJ7-8IEH
# model = RBD53iG-5HacD2HnD
# serial number = <CENSORED>
add admin-mac=2C:C8:1B:61:F6:B7 auto-mac=no comment=defconf mtu=1460 name=bridge
set [ find default-name=ether1 ] advertise=1000M-half,1000M-full l2mtu=1534 mtu=1436
set [ find default-name=ether2 ] advertise=100M-half,100M-full
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn country=italy disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=agv-home wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-eCee country=italy disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=agv-home wireless-protocol=802.11 wps-mode=disabled
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=disabled max-mtu=1480 name=pppoe-out1 service-name=vodafone-internet user=vodafonedsl
/interface ethernet switch
set 0 cpu-flow-control=no
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=208.67.222.222,208.67.220.220
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=pppoe-out1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Rome
/system routerboard settings
set auto-upgrade=yes
/system scheduler
add interval=5m name=Update-OpenDNS on-event=OpenDNS policy=read,write start-time=startup
/system script
<CENSORED>
/tool graphing interface
add allow-address=192.168.88.0/24 interface=pppoe-out1
add allow-address=192.168.88.0/24 interface=ether1
add allow-address=192.168.88.0/24 interface=bridge
/tool mac-server
/tool mac-server mac-winbox
Fai attenzione quando fai gli export anche a gli script… c’era la tua mail nello script OpenDNS…
I read on previous export
/interface vlan
add […] vlan-id=1048
the speedtests are maded by wifi or by cable?
why you reduce MTU on ether1? is pppoe than decide used MTU and 1436 is less than pppoe 1480
Paste this on terminal:
set bridge mtu=auto
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full l2mtu=1600 mtu=1500
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set 0 cpu-flow-control=yes
set [ find default=yes ] authentication-types=wpa2-psk
CAMBIA SUBITO LA PASSWORD OPENDNS!!!
Could it be the same thing I found? http://forum.mikrotik.com/t/hap-ac3-gives-only-half-the-bandwidth-to-linux-boxes-windows-and-bsd-doing-fine/158176/1 I mean as a root cause in forwarding traffic, since you don’t terminate PPPoE on the MT.
