HAP AC3 Slow
When HAP AC3 downloads files, the burst speed can reach 60M, and my operator’s speed is 1000M. However, after the 60M download speed is maintained for 4-6 seconds, the speed starts to drop. Within ten seconds, the speed will be as low as 1M or 500KB. During this period, the CPU sensor is found to be incorrectly displayed. The WINBOX will freeze when viewing other options, and the download speed will also disconnect the flow of 0KB. After ten seconds, the speed will be 20M-30M again, but it will still be down.
It helps when you add a question :wink:
Though Gigabit is really fast (not sure if the RB is capable of Gigabit routing), your RB should be able to handle more than 1M or 500KB.
Can you please share your config (/export hide-sensitive file=anynameyoulike)?
I have reset the system and everything remains default. Only use PPPOE for dialing.
20210705.rsc (7.2 KB)
Tested through wire or wireless? If the latter, you should configure your wireless settings.
Wired test, through the three-layer switch in the middle
Strange…can you supply all relevant information:
  • ISP
  • modem
  • Any other network equipment
  • Testing method (preferably iperf)
  • testing client
Besides, have you checked the http://forum.mikrotik.com/t/v7-1beta6-development-is-released/149195/1 topic for similar problems?
I have tried version 6.48/6.47. The result is the same, the operation in the WINBOX interface will not be refreshed, such as clicking the IP-FIREWALL button, the window interface will not be refreshed immediately, it will be displayed after waiting for 2-3S, and other operations are also true. During this period, the browser cannot open the webpage, and it seems that the network connection is disconnected. There is no problem with my carrier, because I have tested it with other equipment and there is no disconnection problem. IDM is used to download files, and the internal network has not been tested.
Do you really need to use the IPV6 protocol?
Try disabling IPv6 and leaving only ipv4, with your existing default rules. Or will the situation be the same? Testing …
IPV6 was originally disabled, and only IPV4 was used in the 6.48 version test
