Hi
If I switch from hAP ac3 to hAP ax3 can I export my settings/backup from ac3 and import to the new device without issues?
Hi
Most likely not.
Export yes.
Import manually section by section omitting info which is already present (like MAC adresses !).
I think (but not certain) that naming order has changed for Wifi 2.4 / 5GHz so especially pay attention for that as well.
This is a bit more complicated for the wireless part. The new device has ax hardware, thus requires the wifiwave2 package. And that uses different configuration.
So no, even copy and paste from export does not work.
Thank you!
