Hap Ac3 Vlan configuration
Hello , I’m new user of mikrotik products , with better knowledge in Cisco , and I’ve bought the hap ac3 router to learn and play with configuration . I want to make two vlans ( one for lan and one for wlan ) . The hap is connected to my isp router to eth1 . Eth2 should be console and eth3-5 as a switch of vlan 10 , vlan 20 for wlan interfaces . I’ve started from vlan 10 , creating vlan , addresses , dhcp pools , Nat . Then created bridge . I’ve added eth1,3,4,5 to switch ports and bind them with vlan 10 . It worked but I had error with dhcp server - it didn’t give automatically ip , if I give it manual it works . Can someone tell me the steps , maybe I forget something , it would be very apreciated , thanks .!
Go to Para C. Read the first link many times (pcunites bible) → https://forum.mikrotik.com/viewtopic.php?t=182373
