Hello. I have Hap ac3 with LTE port. I want to setup VPN on it. But cant. Internet is from LTE card. LTE is my only one WAN to internet. And i see that my IP address in network is different as in Mikrotik. It looks like Mikrotik dont got public IP from celular operator but got private address from NAT.
So it is reason that can`t setup VPN.
If the other end of the VPN tunnel doesn’t have a public address either, you need a device that does - then both your VPN peers would connect to that third device and it would route the traffic between them.
You have the following possibilities:
run a virtual machine on a public address in a datacenter (so something like $6 per month),
agree with a friend who is more lucky and has got a public IP address, and has a router flexible enough to support such a configuration,
use Zerotier, which is supported in RouterOS 7 on ARM devices
