I will post here because it has been a long time since I used routeros wireless features (around 6.13 or similar8, so I might be missing something basic…
Starting point
- isp cattv modem - hex s - plume access point (managed by the isp)
- brand new hap ac3 connected to the modem (to replace hex and ap
What I did
- update everything to 7.2.1
- export config fro hex s
- resettled the hap with no config
- manually copy and paste the config to the hap
- added the Wi-Fi config to the hap
Issues
“ on hex s I get 320/10 mobs with Speedtest on iPad
- on hap I get 222/6 mbps on the same iPad
Config
add authentication-types=wpa2-psk mode=dynamic-keys name=casa supplicant-identity=MikroTik/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n country=japan disabled=no distance=indoors mode=ap-bridge security-profile=casa
ssid=casa wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40mhz-XX country=japan disabled=no distance=indoors mode=
ap-bridge security-profile=casa ssid=casa
Both devices have the same firewall rules (basically allow lan traffic, block everything else), a whopping 6 filters and 1 nat.
Is there something I am missing ?
Giuliano
