I’ve just noticed that the wifi status led on my HAP ac3 is always off, not blinking or anything, even if wifi is actively used. This led was surely blinking before, then from certain point in time, it stopped. At boot, the led blinks for a while (as well as all the other leds as it normally used to at boot), but then when the system is up and running, the wifi led is completely off. The RouterOS version is 7.1.3.
I have the same issue with my hap ac3. I thought the led has died…Its on ros 7.1.3, and i installed wifivawe2, i think it started happening after i installed wifivawe package, but didn’t notice it at first…
Yes, you’re right! I can confirm. I’ve just disabled the wifiwave2 package and the wifi LED works again. So it must be some incompatibility/bug with the wifiwave2. Should be probably reported then and fixed.
