hap AC3 wifi wave2 setup
Hi ya’ll, please, keep in mind I am still newbie in Mikrotik. I’ve setup my previous one and forgott about him as the router was working perfectly. Recently I’ve switched from hap AC2 to AC3 as I wanted to try the Wave2 wifi, but I feel like I am stupid now as I am unable to make it work. In some cases I can connect to wifi but I can’t obtain any IP.. And sometimes I got local IP but no internet. My idea is very simple - Dual home AP - one 2G wifi and one 5G wifi. For every device on the network (lan, wifi) have assigned IP from 10.1.1.10-10.1.1.254.. nothing else for start.
RouterOS 7.1.1 stable, wave2 from 7.1 stable package.
This is my output of /export compact
add admin-mac=DC:2C:6E:00:A7:90 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=C4:6E:1F:66:FA:19
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifiwave2 channel
add band=2ghz-n frequency=2300-7000 name=ch-2G width=20/40mhz
add band=5ghz-ac frequency=5180 name=ch-5G width=20/40/80mhz
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk encryption=gcmp-256 name=default wps=disable
/interface wifiwave2 configuration
add channel=ch-2G country=Slovakia name=cfg-2G security=default ssid="Net 2G"
add channel=ch-5G country=Slovakia name=cfg-5G security=default ssid="Net 5G"
set [ find default-name=wifi1 ] configuration=cfg-2G configuration.mode=ap disabled=no
set [ find default-name=wifi2 ] configuration=cfg-5G configuration.mode=ap disabled=no
add name=dhcp ranges=10.1.1.10-10.1.1.254
add name=dhcp_wifi1 ranges=10.1.1.10-10.1.1.254
add name=dhcp_wifi2 ranges=10.1.1.10-10.1.1.254
add address-pool=dhcp interface=bridge name=defconf
add address-pool=dhcp_wifi1 interface=wifi1 name=dhcp1
add address-pool=dhcp_wifi2 interface=wifi2 name=dhcp2
add bridge=bridge comment=defconf interface=*6
add bridge=bridge comment=defconf interface=*7
add address=10.1.1.1/24 comment=defconf interface=bridge network=10.1.1.0
add address=10.1.1.1/24 interface=wifi1 network=10.1.1.0
add address=10.1.1.1/24 interface=wifi2 network=10.1.1.0
/ip dhcp-client
add address=10.1.1.0/24 comment=defconf dns-server=10.1.1.1 gateway=10.1.1.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1,8.8.8.8
/ip dns static
add address=10.1.1.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Bratislava
/system logging
add topics=wireless,debug
/system routerboard settings
set cpu-frequency=auto
/tool mac-server
/tool mac-server mac-winbox
Remove any configuration from interfaces wifi1 and wifi2 (IP address, DHCP server etc.). Add interfaces wifi1 and wifi2 to bridge. Remove the unknown interfaces (marked as *6 and *7 in export) from bridge (they are likely remains from using legacy wireless driver).
Is there a reason for three address pools referencing the same network?
You only need one because you’re specifying one network range.
DHCP will operate on the bridge interface so allocating different pools only makes sense if you want separate addresses for 2.4 vs 5.
There’s no need to overdo it.
@mkx thank you, that helped.. just a quick note. ROS v7.1 stable is missing interfaces > port tab in the gui. Is accessible through terminal though.
Wifi speed is now at full speed!
Now just find out why my latest phone wont connect.. but that’s another story
Edit - just a quick note: Xiaomi Mi8 is unable to connect to wifi (wifi connected, saved, but nothing else) with WPA2/3 encryption GCMP/GCMP 256, but some other much older devices as Xiaomi Mi4C, MBP2015 were connecting without any problem. So I’ve set encryption cyphers to CCMP/CCMP 256 and every device is now connecting flawlessly.
@rfc1149 extra pools for wifi were a ‘fix’ I saw in other topics and were made as an experiment because wifi didn’t want assign any IP address.. pools are gone now and everything works.
This is my current startingpoint setup:
add authentication-types=wpa2-psk,wpa3-psk encryption=ccmp,gcmp,ccmp-256,gcmp-256 name=default wps=disable
set [ find default-name=wifi1 ] channel=ch-2G configuration=cfg-2G configuration.mode=ap disabled=no security=default
set [ find default-name=wifi2 ] channel=ch-5G configuration=cfg-5G configuration.mode=ap disabled=no security=default
add bridge=bridge interface=wifi1
add bridge=bridge interface=wifi2
/ip dhcp-client
/ip dns static
/system clock
/system logging
/tool mac-server
Now that original problem is solved …
@rfc1149, did you ever see your nick perform in real life? I haven’t, but it would be interesting …
Sweet! Glad you resolved your issue.
When I first started using Mikrotik, the whole idea of a bridge seemed weird and I didn’t like it.
However once I learned that it was integral, I embraced it and haven’t looked back since.
WAN ports can never be a bridge port because they cannot operate in slave mode.
Everything that would reasonably be expected to have connectivity to the local network should be a bridge port.
The correct answer is usually the simplest. Happy networking. :smiley:
Of course. :sunglasses:
https://www.wired.com/2009/09/in-africa-a-pigeon-transfers-data-faster-than-the-internet/
By selecting 802.11n only for 2.4GHz, you’ve limited the operation mode to 802.11n clients.
This prevents compatibility and some devices may behave weirdly when they see a network without basic support for 802.11g.
It goes back to OEM decisions for the chipset of the client device and sometimes parameter customisation decisions for the OS variant.
Too many to list but you get the idea, not all clients behave the same as each other as a result. Too many moving parts. :smiley:
If you’re using the same SSID for 2.4GHz and 5GHz then you can have AES CCMP and GCMP enabled for the security profile because WPA3 supports backwards compatibility.
It shouldn’t be an issue but my previous statement about wireless client behaviour still stands.
I usually have 802.11 G+N at least for 2.4GHz and for 5GHz N+AC. YMMV. Test, test again. See what works.
Not really the case … what article describes falls in category of “never underestimate the bandwidth of a station wagon” …
Fair enough. I don’t think we will ever realise the true potential of IPoAC. :frowning:
There’s this: https://www.blug.linux.no/rfc1149/writeup/
But the throughput and latency were terrible, not something you’d want to use regularly. :wink:
Yup, I knew there were a few rare events doing it in reality, I was wondering if anybody around here saw it in person.
I wouldn’t expect large overlap between networking and pigeon enthusiats, that may be one problem. I for one have several routers, but zero pigeons or other birds. I do have cat, so in theory, if you wouldn’t insist on aerial transport, … but good luck training cats to do what you want. :slight_smile:
I guess you could deploy your cat as raw firewall rule in IPoAC :laughing:
/ip/firewall/filter/add chain=input action=feed-cat comment=meow
