hAP and NAND
Hello!
I have hAP 951Ui-2nD and i need to make backup config to internal memory. It’s ok, but after reboot no seems no one files in internal storage, they disappeared. Also counters “Free HDD Space” and “Sector writes sinse reboots” and “Total sector writes” are freezed and no changed.
I had tried to copy some file from PC to hAP, also after reboot file is disappeared.
I also saw that the amount of RAM is reduced in accordance with the size of the file passed from the PC. It is very strange.
ROS 6.36.3 (stable)
Firmware 3.33
Try to use the /flash folder.
With /flash folder working normally, thanks!
