I’ve bought hap ax^2 and setup everything via quick set (plus special classes for DHCP client). Everything was working properly, but today router removed 5G network. After setting everything up via quick set again, the wifi interface is not running. What can I do to make it work again?
# 2023-08-06 22:32:20 by RouterOS 7.10.2
# software id = 9148-ZHI4
# model = C52iG-5HaxD2HaxD
add admin-mac= auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ac .skip-dfs-channels=\
10min-cac configuration.hide-ssid=no .mode=ap .ssid=MikroTik-5 disabled=\
no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
configuration.mode=ap .ssid=MikroTik-2 disabled=no \
add configuration.ssid=MikroTik-Guests disabled=no mac-address=\
master-interface=wifi1 name=wifi3
master-interface=wifi2 name=wifi4
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/interface bridge filter
add action=drop chain=forward in-interface=wifi3
add action=drop chain=forward out-interface=wifi3
add action=drop chain=forward in-interface=wifi4
add action=drop chain=forward out-interface=wifi4
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=bridge interface=wifi3
add bridge=bridge interface=wifi4
192.168.88.0
/ip dhcp-client
add add-default-route=special-classless comment=defconf interface=ether1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Kiev
/system note
set show-at-login=no
/system package update
set channel=testing
/tool mac-server
/tool mac-server mac-winbox
