hAP ax² dual band Wi-Fi 6 (802.11ax)
It’s started…
https://www.youtube.com/watch?v=aRPKUDvNyjM
anyone found the product page yet?
Ask your distributor, i think this video is from latest news for distibutors, only this time MikroTik leaked it themselves :slight_smile:
Looks sweet !
It’s a pity though in the video he claims “I constantly see speeds above 800mb” yet the speedtest screen shown at that moment clearly shows below 800 all the time.
1GB RAM… I wonder when we will finally get RAMDISK on devices like that, otherwise it will be useless to have it.
Let’s see how much FLASH we get this time :slight_smile:
Awesome! Nice to see PoE in
hAP ac2 already had PoE in. It is only the PoE out that is new. And hopefully now it is 802.11af/at instead if “passive PoE”…
Eish!!! And I just upgraded from AC2 to AC3 a couple of months ago, now I have to buy a new one :frowning:
But glad it is eventually here though
Too bad though PoE In and Out are on the same port from what I can see.
What would be the logic behind that ?
hAP ac3 should already provide most of what hAP ax2 has to offer… no need to buy a new one again, I would say.
I don’t understand that either. I would expect the PoE out on ether5. But maybe it saves some components…
This is smallest dual-band ax device i have seen so far - i think this is one of many compromises they had to make for this form factor.
would be good to know price, that might also explain a lot.
Next week the Audience ax³ :laughing:
I want one Audience ax³
Well, I totally agree with you. Normis stated that MT does not restrict their clients with a subscription. But, I consider a small disk a restriction.
I guess 128 MB or maximum 256 MB. It will be able to run the new wifiwave drivers…where you can already see the supporteed chipset…
IPQ 4019
IPQ 5018
IPQ 6018
IPQ 8074
IPQ 8074v2
QCA9888
QCA9984
So we can guess which chiset is in the hAP ax2. Probably it will be IPQ 8074, so Im worried about high price. Even hAP AC3, with wifi 5 cost as wifi 6 routers competitors…
Official PDF: https://mt.lv/hap_ax2
From Product PDF:
Specifications
Product code C52iG-5HaxD2HaxD-TC
CPU Quad-Core IPQ-6010 864 MHz
CPU architecture ARM 64bit
Size of RAM 1 GB
Storage 128 MB, NAND
Number of 1G Ethernet ports 5
Number of 1G Ethernet ports with PoE-out 1
Switch chip model IPQ-6010
Wireless interface model QCN-5052
Wireless 2.4 GHz 802.11ax dual-chain, 5 GHz 802.11 802.11ax dual-chain
Wireless antenna max gain 2.4 GHz (4.5 dBi), 5 GHz (4 dBi)
Dimensions 120 x 101 x 37 mm
Operating system RouterOS, License level 4
Operating temperature -40°C to +50°C
Rate (2.4 GHz) Tx (dBm) Rx (dBm)
1MBit/s 22 -100
11MBit/s 22 -94
6MBit/s 24 -96
54MBit/s 22 -80
MCS0 24 -96
MCS7 21 -75
MCS9 19 -70
MCS11 17 -67
Rate (5 GHz) Tx (dBm) Rx (dBm)
6MBit/s 23 -96
54MBit/s 20 -80
MCS0 22 -96
MCS7 19 -75
MCS9 17 -70
MCS11 15 -67
Wireless specifications
5hAP ax²
Included parts
24 V 1.2 A
power adapter
Case baseFastening
set
I don’t see an USB port, sad.
Just link the PDF, sheesh.
i think is not easy to cramp features in so small footprint
EDITED Hap ac2 in fact have USB port
Do some research before posting, if you don’t own the device.
https://mikrotik.com/product/hap_ac2#fndtn-specifications
USB slot type USB type A
You can almost see it in the gallery too https://mikrotik.com/product/hap_ac2#fndtn-gallery
Short version: hAP ac2 has an USB port, USB2.0, but it has it.
