For some reasons, the LTE interface on hAP ax lite LTE6 doesn’t connect to cellular network. I upgrade the RouterOS to latest stable and the modem firmware to latest available:
16121.1034.00.01.01.04
What would be be the issue? The same sim card works seamlessly in another LTE router or in a phone
The modem-init workaround is taken from this thread http://forum.mikrotik.com/t/hap-ax-lite-lte6-wont-connect-to-cellular-network/172195/1
[admin@MikroTik] > interface/lte/ print
Columns: NAME, MTU, NETWORK-MODE, APN-PROFILES
# NAME MTU NETWORK-MODE APN-PROFILES
0 lte1 1500 3g tesla
lte
[admin@MikroTik] > interface/lte/ print detail
Flags: X - disabled; R - running
0 default-name="lte1" name="lte1" mtu=1500 apn-profiles=tesla
modem-init="AT+CGDCONT=0,"IPV4V6","tesla01.com.attz";AT+CGDCONT=1,"IPV4V6",
"tesla01.com.attz""
allow-roaming=no sms-read=no network-mode=3g,lte band=""
[admin@MikroTik] > interface/lte/apn/ print detail
Flags: * - default
0 * name="default" apn="internet" use-peer-dns=yes use-network-apn=yes
add-default-route=yes default-route-distance=2 ip-type=auto
authentication=none
1 name="tesla" apn="tesla01.com.attz" use-peer-dns=yes use-network-apn=no
authentication=none
[admin@MikroTik] > system/res
resource reset-configuration
[admin@MikroTik] > system/resource/print
uptime: 7m31s
version: 7.14.3 (stable)
build-time: 2024-04-17 12:47:58
factory-software: 7.8
free-memory: 89.1MiB
total-memory: 224.0MiB
cpu: ARM
cpu-count: 2
cpu-frequency: 800MHz
cpu-load: 3%
free-hdd-space: 97.9MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 62
write-sect-total: 29139
bad-blocks: 0%
architecture-name: arm
board-name: hAP ax lite LTE6
platform: MikroTik
21:59:00 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:00 lte,async,raw lte1: rcvd +GTANTINFO: "0",46,15
21:59:00 lte,async,raw lte1: rcvd +GTANTINFO: "1",28,6
21:59:02 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:02 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:02 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:02 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:02 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:03 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:03 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:03 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,12,24,43,41463,20560
21:59:03 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
21:59:03 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:03 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:03 lte,async,raw lte1: rcvd LTE service cell:
21:59:03 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,24,45,45,12
21:59:03 lte,async,raw lte1: rcvd LTE neighbor cell:
21:59:03 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,36,36,0
21:59:03 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:03 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,12
21:59:03 lte,async,raw lte1: rcvd +GTANTINFO: "1",29,10
21:59:06 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:06 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:06 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,43,15,6,40,41463,20560
21:59:06 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
21:59:06 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:06 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:06 lte,async,raw lte1: rcvd LTE service cell:
21:59:06 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,6,43,43,15
21:59:06 lte,async,raw lte1: rcvd LTE neighbor cell:
21:59:06 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
21:59:06 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:06 lte,async,raw lte1: rcvd +GTANTINFO: "0",43,15
21:59:06 lte,async,raw lte1: rcvd +GTANTINFO: "1",29,19
21:59:06 lte,debug lte1 mbim: forced reconfiguration due to long search time
21:59:06 lte,debug lte1 mbim: state 11=>5
21:59:06 lte,debug lte1 mbim: set radio: off
21:59:06 lte,debug lte1 mbim: <<< S - connect: radio state
21:59:06 lte,packet,raw lte1 mbim: wdm <<< send #16
21:59:06 lte,packet,raw lte1 mbim: 03000000 34000000 10000000 01000000
21:59:06 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:06 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
21:59:06 lte,async,raw lte1: +CGREG: 0
21:59:06 lte,async,raw lte1: +CEREG: 0
21:59:06 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:06 lte,packet,raw lte1 mbim: 07000080 30000000 00000000 01000000
21:59:06 lte,packet,raw lte1 mbim: c2aae6df 16000000 04000000 00000000
21:59:06 lte,debug lte1 mbim: >>> N - connect: emergency mode
21:59:06 lte,packet lte1 mbim: status data:
21:59:06 lte,packet lte1 mbim: 00000000
21:59:06 lte,debug lte1 mbim: unhandled command: emergency mode
21:59:07 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:07 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:07 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:07 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:07 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:07 lte,packet,raw lte1 mbim: wdm >>> recv #16
21:59:07 lte,packet,raw lte1 mbim: 03000080 38000000 10000000 01000000
21:59:07 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
21:59:07 lte,packet,raw lte1 mbim: 01000000 00000000
21:59:07 lte,debug lte1 mbim: >>> D - connect: radio state
21:59:07 lte,packet lte1 mbim: status data:
21:59:07 lte,packet lte1 mbim: 01000000 00000000
21:59:07 lte,debug lte1 mbim: state 5=>6
21:59:07 lte,async lte1: sent AT+GTACT=10,,,0
21:59:07 lte,async lte1: rcvd OK
21:59:07 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:07 lte,debug lte1 mbim: state 6=>7
21:59:07 lte,debug lte1 mbim: <<< Q - connect: subscriber ready status
21:59:07 lte,packet,raw lte1 mbim: wdm <<< send #17
21:59:07 lte,packet,raw lte1 mbim: 03000000 30000000 11000000 01000000
21:59:07 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 00000000
21:59:07 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:07 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:07 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:07 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:07 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:07 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:07 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:07 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:07 lte,packet,raw lte1 mbim: wdm >>> recv #17
21:59:07 lte,packet,raw lte1 mbim: 03000080 94000000 11000000 01000000
21:59:07 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 64000000
21:59:07 lte,packet,raw lte1 mbim: 01000000 1c000000 1e000000 3c000000
21:59:07 lte,packet,raw lte1 mbim: 28000000 00000000 00000000 33003100
21:59:07 lte,packet,raw lte1 mbim: 30003100 37003000 32003000 35003600
21:59:07 lte,packet,raw lte1 mbim: 33003300 37003200 32000000 38003900
21:59:07 lte,packet,raw lte1 mbim: 30003100 31003700 30003200 32003700
21:59:07 lte,packet,raw lte1 mbim: 32003000 35003600 33003300 37003200
21:59:07 lte,debug lte1 mbim: >>> D - connect: subscriber ready status
21:59:07 lte,packet lte1 mbim: 01000000 1c000000 1e000000 3c000000
21:59:07 lte,packet lte1 mbim: 28000000 00000000 00000000 33003100
21:59:07 lte,packet lte1 mbim: 30003100 37003000 32003000 35003600
21:59:07 lte,packet lte1 mbim: 33003300 37003200 32000000 38003900
21:59:07 lte,packet lte1 mbim: 30003100 31003700 30003200 32003700
21:59:07 lte,packet lte1 mbim: 32003000 35003600 33003300 37003200
21:59:07 lte,debug lte1 mbim: subscriber ready state: initialized
21:59:07 lte,async lte1: sent AT+CGAUTH=1,0
21:59:07 lte,debug lte1 mbim: state 7=>10
21:59:07 lte,debug lte1 mbim: request register, operator: [auto]
21:59:07 lte,debug lte1 mbim: <<< S - connect: register state
21:59:07 lte,packet,raw lte1 mbim: wdm <<< send #18
21:59:07 lte,packet,raw lte1 mbim: 03000000 40000000 12000000 01000000
21:59:07 lte,packet,raw lte1 mbim: c2aae6df 09000000 01000000 10000000
21:59:07 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 3b000000
21:59:07 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
21:59:07 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
21:59:07 lte,packet,raw lte1 mbim: 01000000 01000000 00000000 01000000
21:59:07 lte,packet,raw lte1 mbim: 30000000 00000000 30000000 00000000
21:59:07 lte,packet,raw lte1 mbim: 30000000 00000000 00000000
21:59:07 lte,debug lte1 mbim: >>> N - connect: register state
21:59:07 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
21:59:07 lte,packet lte1 mbim: 01000000 30000000 00000000 30000000
21:59:07 lte,packet lte1 mbim: 00000000 30000000 00000000 00000000
21:59:07 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
21:59:07 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
21:59:07 lte,packet,raw lte1 mbim: 04000000 00000000 00000000 00000000
21:59:07 lte,debug lte1 mbim: >>> N - connect: packet service
21:59:07 lte,packet lte1 mbim: 00000000 04000000 00000000 00000000
21:59:07 lte,packet lte1 mbim: 00000000 00000000 00000000
21:59:07 lte,debug lte1 mbim: packet service: detached data class: 0 nwe:
21:59:08 lte,packet,raw lte1 mbim: wdm >>> recv #18
21:59:08 lte,packet,raw lte1 mbim: 03000080 60000000 12000000 01000000
21:59:08 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:08 lte,packet,raw lte1 mbim: c2aae6df 09000000 00000000 30000000
21:59:08 lte,packet,raw lte1 mbim: 00000000 01000000 01000000 00000000
21:59:08 lte,packet,raw lte1 mbim: 01000000 30000000 00000000 30000000
21:59:08 lte,packet,raw lte1 mbim: 00000000 30000000 00000000 00000000
21:59:08 lte,debug lte1 mbim: >>> D - connect: register state
21:59:08 lte,packet lte1 mbim: status data:
21:59:08 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
21:59:08 lte,packet lte1 mbim: 01000000 30000000 00000000 30000000
21:59:08 lte,packet lte1 mbim: 00000000 30000000 00000000 00000000
21:59:08 lte,debug lte1 mbim: register state: deregistered
21:59:08 lte,debug lte1 mbim: state 10=>11
21:59:08 lte,debug lte1 mbim: set radio: on
21:59:08 lte,debug lte1 mbim: <<< S - connect: radio state
21:59:08 lte,packet,raw lte1 mbim: wdm <<< send #19
21:59:08 lte,packet,raw lte1 mbim: 03000000 34000000 13000000 01000000
21:59:08 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
21:59:08 lte,packet,raw lte1 mbim: wdm >>> recv #19
21:59:08 lte,packet,raw lte1 mbim: 03000080 38000000 13000000 01000000
21:59:08 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
21:59:08 lte,packet,raw lte1 mbim: 01000000 01000000
21:59:08 lte,debug lte1 mbim: >>> D - connect: radio state
21:59:08 lte,packet lte1 mbim: 01000000 01000000
21:59:10 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:10 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:10 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:10 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:10 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:10 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:10 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:10 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:10 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:12 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:12 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:12 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:12 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:12 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:13 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:13 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:13 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:13 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:13 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:13 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:13 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:13 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:13 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:16 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:16 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:16 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:16 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:16 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:16 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:16 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:16 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:16 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:17 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:17 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:17 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:17 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:17 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:19 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:19 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:19 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:19 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:19 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:19 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:19 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:19 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:19 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:22 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:22 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:22 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:22 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:22 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:22 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:22 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:22 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:22 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:22 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:22 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:22 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:22 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:22 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:25 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:25 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:25 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:25 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:25 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:25 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:25 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:25 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:25 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:27 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:27 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:27 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:27 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:27 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:28 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:28 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:28 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:28 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:28 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:28 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:28 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:28 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:28 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:31 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:31 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:31 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:31 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:31 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:31 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:31 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:31 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:31 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:32 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:32 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:32 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:32 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:32 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:34 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:34 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:34 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:34 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:34 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:34 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:34 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:34 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:34 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:37 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:37 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:37 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:37 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:37 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:37 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:37 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:37 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:37 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:37 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:37 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:37 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:37 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:37 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:40 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:40 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:40 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:40 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:40 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:40 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:40 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:40 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:40 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:42 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:42 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:42 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:42 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:42 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:43 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:43 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:43 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:43 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:43 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:43 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:43 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:43 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:43 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:46 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:46 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:46 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
21:59:46 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:46 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:46 lte,async,raw lte1: rcvd 2,0,0,00,,,,,,,,,,,
21:59:46 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:46 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
21:59:46 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
21:59:47 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:47 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:47 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:47 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:47 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:47 lte,async,raw lte1: +CGREG: 2
21:59:47 lte,packet,raw lte1 mbim: 07000080 30000000 00000000 01000000
21:59:47 lte,packet,raw lte1 mbim: c2aae6df 16000000 04000000 01000000
21:59:47 lte,debug lte1 mbim: >>> N - connect: emergency mode
21:59:47 lte,packet lte1 mbim: status data:
21:59:47 lte,packet lte1 mbim: 01000000
21:59:47 lte,debug lte1 mbim: unhandled command: emergency mode
21:59:47 lte,async,raw lte1: +CEREG: 2
21:59:47 lte,async,raw lte1: +CGREG: 0
21:59:47 lte,async,raw lte1: +CEREG: 0
21:59:47 lte,packet,raw lte1 mbim: 07000080 68000000 00000000 01000000
21:59:47 lte,packet,raw lte1 mbim: c2aae6df 09000000 3c000000 00000000
21:59:47 lte,packet,raw lte1 mbim: 00000000 01000000 00000000 01000000
21:59:47 lte,packet,raw lte1 mbim: 30000000 0c000000 3c000000 00000000
21:59:47 lte,packet,raw lte1 mbim: 3c000000 00000000 00000000 33003100
21:59:47 lte,packet,raw lte1 mbim: 31003400 38003000
21:59:47 lte,debug lte1 mbim: >>> N - connect: register state
21:59:47 lte,packet lte1 mbim: 00000000 00000000 01000000 00000000
21:59:47 lte,packet lte1 mbim: 01000000 30000000 0c000000 3c000000
21:59:47 lte,packet lte1 mbim: 00000000 3c000000 00000000 00000000
21:59:47 lte,packet lte1 mbim: 33003100 31003400 38003000
21:59:47 lte,debug lte1 mbim: register state: unknown, gsm operator: 311480,
21:59:47 lte,debug lte1 mbim: waiting for modem to make up it's mind
21:59:47 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
21:59:47 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
21:59:47 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
21:59:47 lte,debug lte1 mbim: >>> N - connect: packet service
21:59:47 lte,packet lte1 mbim: 00000000 00000000 00000000 00000000
21:59:47 lte,debug lte1 mbim: packet service: unknown data class: 0 nwe:
21:59:49 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:49 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:49 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,46,25,24,39,41463,20560
21:59:49 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
21:59:49 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:49 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:49 lte,async,raw lte1: rcvd LTE service cell:
21:59:49 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,24,46,46,25
21:59:49 lte,async,raw lte1: rcvd LTE neighbor cell:
21:59:49 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:49 lte,async,raw lte1: rcvd +GTANTINFO: "0",46,25
21:59:49 lte,async,raw lte1: rcvd +GTANTINFO: "1",32,25
21:59:52 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:52 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:52 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:52 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:52 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:52 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:52 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:52 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,24,22,38,41463,20560
21:59:52 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
21:59:52 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:52 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:52 lte,async,raw lte1: rcvd LTE service cell:
21:59:52 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,22,45,45,24
21:59:52 lte,async,raw lte1: rcvd LTE neighbor cell:
21:59:52 lte,async,raw lte1: rcvd 2,4,,,,,A00,E9,,36,36,4
21:59:52 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,32,32,0
21:59:52 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:52 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,24
21:59:52 lte,async,raw lte1: rcvd +GTANTINFO: "1",31,25
21:59:55 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:55 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:55 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,24,22,38,41463,20560
21:59:55 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
21:59:55 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:55 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:55 lte,async,raw lte1: rcvd LTE service cell:
21:59:55 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,22,45,45,24
21:59:55 lte,async,raw lte1: rcvd LTE neighbor cell:
21:59:55 lte,async,raw lte1: rcvd 2,4,,,,,A00,E9,,36,36,4
21:59:55 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,32,32,0
21:59:55 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:55 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,24
21:59:55 lte,async,raw lte1: rcvd +GTANTINFO: "1",31,25
21:59:57 lte,packet,raw lte1 mbim: wdm >>> recv #0
21:59:57 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
21:59:57 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
21:59:57 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
21:59:57 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
21:59:58 lte,async,raw lte1: sent AT+GTCAINFO?
21:59:58 lte,async,raw lte1: rcvd +GTCAINFO:
21:59:58 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,24,22,38,41463,20560
21:59:58 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
21:59:58 lte,async,raw lte1: sent AT+GTCCINFO?
21:59:58 lte,async,raw lte1: rcvd +GTCCINFO:
21:59:58 lte,async,raw lte1: rcvd LTE service cell:
21:59:58 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,22,45,45,24
21:59:58 lte,async,raw lte1: rcvd LTE neighbor cell:
21:59:58 lte,async,raw lte1: rcvd 2,4,,,,,A00,E9,,36,36,4
21:59:58 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,32,32,0
21:59:58 lte,async,raw lte1: sent AT+GTANTINFO?
21:59:58 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,24
21:59:58 lte,async,raw lte1: rcvd +GTANTINFO: "1",31,25
22:00:01 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:01 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:01 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,24,22,38,41463,20560
22:00:01 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:01 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:01 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:01 lte,async,raw lte1: rcvd LTE service cell:
22:00:01 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,22,45,45,24
22:00:01 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:01 lte,async,raw lte1: rcvd 2,4,,,,,A00,E9,,36,36,4
22:00:01 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,32,32,0
22:00:01 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:01 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,24
22:00:01 lte,async,raw lte1: rcvd +GTANTINFO: "1",31,25
22:00:02 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:02 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:02 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:02 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:02 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:04 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:04 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:04 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,24,22,38,41463,20560
22:00:04 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:04 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:04 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:04 lte,async,raw lte1: rcvd LTE service cell:
22:00:04 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,22,45,45,24
22:00:04 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:04 lte,async,raw lte1: rcvd 2,4,,,,,A00,E9,,36,36,4
22:00:04 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,32,32,0
22:00:04 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:04 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,24
22:00:04 lte,async,raw lte1: rcvd +GTANTINFO: "1",31,25
22:00:07 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:07 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:07 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:07 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:07 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:07 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:07 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:07 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,24,22,38,41463,20560
22:00:07 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:07 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:07 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:07 lte,async,raw lte1: rcvd LTE service cell:
22:00:07 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,22,45,45,24
22:00:07 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:07 lte,async,raw lte1: rcvd 2,4,,,,,A00,E9,,36,36,4
22:00:07 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,32,32,0
22:00:07 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:07 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,24
22:00:07 lte,async,raw lte1: rcvd +GTANTINFO: "1",31,25
22:00:10 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:10 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:10 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,24,22,38,41463,20560
22:00:10 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:10 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:10 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:10 lte,async,raw lte1: rcvd LTE service cell:
22:00:10 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,22,45,45,24
22:00:10 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:10 lte,async,raw lte1: rcvd 2,4,,,,,A00,E9,,36,36,4
22:00:10 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,32,32,0
22:00:10 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:10 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,24
22:00:10 lte,async,raw lte1: rcvd +GTANTINFO: "1",31,25
22:00:12 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:12 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:12 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:12 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:12 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:13 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:13 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:13 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,24,22,38,41463,20560
22:00:13 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:13 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:13 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:13 lte,async,raw lte1: rcvd LTE service cell:
22:00:13 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,22,45,45,24
22:00:13 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:13 lte,async,raw lte1: rcvd 2,4,,,,,A00,E9,,36,36,4
22:00:13 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,32,32,0
22:00:13 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:13 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,24
22:00:13 lte,async,raw lte1: rcvd +GTANTINFO: "1",31,25
22:00:16 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:16 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:16 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,24,22,38,41463,20560
22:00:16 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:16 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:16 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:16 lte,async,raw lte1: rcvd LTE service cell:
22:00:16 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,22,45,45,24
22:00:16 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:16 lte,async,raw lte1: rcvd 2,4,,,,,A00,E9,,36,36,4
22:00:16 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,32,32,0
22:00:16 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:17 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,24
22:00:17 lte,async,raw lte1: rcvd +GTANTINFO: "1",31,25
22:00:17 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:17 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:17 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:17 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:17 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:20 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:20 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:20 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:00:20 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:20 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:20 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:20 lte,async,raw lte1: rcvd LTE service cell:
22:00:20 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:00:20 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:20 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:20 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:00:20 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:00:22 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:22 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:22 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:22 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:22 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:23 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:23 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:23 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:00:23 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:23 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:23 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:23 lte,async,raw lte1: rcvd LTE service cell:
22:00:23 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:00:23 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:23 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:23 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:00:23 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:00:26 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:26 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:26 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:00:26 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:26 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:26 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:26 lte,async,raw lte1: rcvd LTE service cell:
22:00:26 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:00:26 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:26 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:26 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:00:26 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:00:27 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:27 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:27 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:27 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:27 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:29 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:29 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:29 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,41463,0
22:00:29 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:29 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:29 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:29 lte,async,raw lte1: rcvd LTE service cell:
22:00:29 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:00:29 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:29 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:29 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:00:29 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:00:32 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:32 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:32 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,44,20,14,39,41463,20560
22:00:32 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:32 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:32 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:32 lte,async,raw lte1: rcvd LTE service cell:
22:00:32 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,14,44,44,20
22:00:32 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:32 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
22:00:32 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:32 lte,async,raw lte1: rcvd +GTANTINFO: "0",44,20
22:00:32 lte,async,raw lte1: rcvd +GTANTINFO: "1",30,21
22:00:32 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:32 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:32 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:32 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:32 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:35 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:35 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:35 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,21,16,39,41463,20560
22:00:35 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:35 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:35 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:35 lte,async,raw lte1: rcvd LTE service cell:
22:00:35 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,16,45,45,21
22:00:35 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:35 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
22:00:35 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:35 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,21
22:00:35 lte,async,raw lte1: rcvd +GTANTINFO: "1",30,22
22:00:37 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:37 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:37 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:37 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:37 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:38 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:38 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:38 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,21,16,39,41463,20560
22:00:38 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:38 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:38 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:38 lte,async,raw lte1: rcvd LTE service cell:
22:00:38 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,16,45,45,21
22:00:38 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:38 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
22:00:38 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:38 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,21
22:00:38 lte,async,raw lte1: rcvd +GTANTINFO: "1",30,22
22:00:41 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:41 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:41 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,21,16,39,41463,20560
22:00:41 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:41 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:41 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:41 lte,async,raw lte1: rcvd LTE service cell:
22:00:41 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,16,45,45,21
22:00:41 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:41 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
22:00:41 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:41 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,21
22:00:41 lte,async,raw lte1: rcvd +GTANTINFO: "1",30,22
22:00:42 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:42 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:42 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:42 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:42 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:44 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:44 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:44 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,21,16,39,41463,20560
22:00:44 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:44 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:44 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:44 lte,async,raw lte1: rcvd LTE service cell:
22:00:44 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,16,45,45,21
22:00:44 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:44 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
22:00:44 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:44 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,21
22:00:44 lte,async,raw lte1: rcvd +GTANTINFO: "1",30,22
22:00:47 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:47 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:47 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,21,16,39,41463,20560
22:00:47 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:47 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:47 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:47 lte,async,raw lte1: rcvd LTE service cell:
22:00:47 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,16,45,45,21
22:00:47 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:47 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
22:00:47 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:47 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,21
22:00:47 lte,async,raw lte1: rcvd +GTANTINFO: "1",30,22
22:00:47 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:47 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:47 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:47 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:47 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:50 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:50 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:50 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,21,16,39,41463,20560
22:00:50 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:50 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:50 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:50 lte,async,raw lte1: rcvd LTE service cell:
22:00:50 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,16,45,45,21
22:00:50 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:50 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
22:00:50 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:50 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,21
22:00:50 lte,async,raw lte1: rcvd +GTANTINFO: "1",30,22
22:00:52 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:52 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:52 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:52 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:52 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:53 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:53 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:53 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,21,16,39,41463,20560
22:00:53 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:53 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:53 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:53 lte,async,raw lte1: rcvd LTE service cell:
22:00:53 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,16,45,45,21
22:00:53 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:53 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
22:00:53 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:53 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,21
22:00:53 lte,async,raw lte1: rcvd +GTANTINFO: "1",30,22
22:00:56 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:56 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:56 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,21,16,39,41463,20560
22:00:56 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:56 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:56 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:56 lte,async,raw lte1: rcvd LTE service cell:
22:00:56 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,16,45,45,21
22:00:56 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:56 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
22:00:56 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:56 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,21
22:00:56 lte,async,raw lte1: rcvd +GTANTINFO: "1",30,22
22:00:57 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:00:57 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:00:57 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:00:57 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:00:57 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:00:59 lte,async,raw lte1: sent AT+GTCAINFO?
22:00:59 lte,async,raw lte1: rcvd +GTCAINFO:
22:00:59 lte,async,raw lte1: rcvd PCC:105,339,2560,50,0,45,21,16,39,41463,20560
22:00:59 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:00:59 lte,async,raw lte1: sent AT+GTCCINFO?
22:00:59 lte,async,raw lte1: rcvd +GTCCINFO:
22:00:59 lte,async,raw lte1: rcvd LTE service cell:
22:00:59 lte,async,raw lte1: rcvd 1,4,311,480,2901,A1F713,A00,153,5,50,16,45,45,21
22:00:59 lte,async,raw lte1: rcvd LTE neighbor cell:
22:00:59 lte,async,raw lte1: rcvd 2,4,,,,,A00,1F,,35,35,0
22:00:59 lte,async,raw lte1: sent AT+GTANTINFO?
22:00:59 lte,async,raw lte1: rcvd +GTANTINFO: "0",45,21
22:00:59 lte,async,raw lte1: rcvd +GTANTINFO: "1",30,22
22:01:02 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:02 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:01:02 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:01:02 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:01:02 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:01:02 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:01:02 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:02 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:02 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:02 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:02 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:02 lte,async,raw lte1: rcvd LTE service cell:
22:01:02 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:02 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:02 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:02 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:02 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:05 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:05 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:05 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:05 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:05 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:05 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:05 lte,async,raw lte1: rcvd LTE service cell:
22:01:05 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:05 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:05 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:05 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:05 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:07 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:01:07 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:01:07 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:01:07 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:01:07 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:01:08 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:08 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:08 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:08 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:08 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:08 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:08 lte,async,raw lte1: rcvd LTE service cell:
22:01:08 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:08 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:08 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:08 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:08 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:08 lte,debug lte1 mbim: retrying registration
22:01:08 lte,debug lte1 mbim: request register, operator: [auto]
22:01:08 lte,debug lte1 mbim: <<< S - connect: register state
22:01:08 lte,packet,raw lte1 mbim: wdm <<< send #20
22:01:08 lte,packet,raw lte1 mbim: 03000000 40000000 14000000 01000000
22:01:08 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:01:08 lte,packet,raw lte1 mbim: c2aae6df 09000000 01000000 10000000
22:01:08 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 3b000000
22:01:11 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:11 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:11 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:11 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:11 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:11 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:11 lte,async,raw lte1: rcvd LTE service cell:
22:01:11 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:11 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:11 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:11 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:11 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:12 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:01:12 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:01:12 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:01:12 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:01:12 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:01:14 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:14 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:14 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:14 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:14 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:14 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:14 lte,async,raw lte1: rcvd LTE service cell:
22:01:14 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:14 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:14 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:14 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:14 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:17 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:01:17 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:01:17 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:01:17 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:01:17 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:01:17 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:17 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:17 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:17 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:17 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:17 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:17 lte,async,raw lte1: rcvd LTE service cell:
22:01:17 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:17 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:17 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:17 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:17 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:20 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:20 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:20 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:20 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:20 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:20 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:20 lte,async,raw lte1: rcvd LTE service cell:
22:01:20 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:20 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:20 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:20 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:20 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:22 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:01:22 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:01:22 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:01:22 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:01:22 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:01:23 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:23 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:23 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:23 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:23 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:23 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:23 lte,async,raw lte1: rcvd LTE service cell:
22:01:23 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:23 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:23 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:23 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:23 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:26 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:26 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:26 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:26 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:26 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:26 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:26 lte,async,raw lte1: rcvd LTE service cell:
22:01:26 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:26 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:26 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:26 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:26 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:27 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:01:27 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:01:27 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:01:27 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:01:27 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:01:29 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:29 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:29 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:29 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:29 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:29 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:29 lte,async,raw lte1: rcvd LTE service cell:
22:01:29 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:29 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:29 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:29 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:29 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:32 lte,packet,raw lte1 mbim: wdm >>> recv #0
22:01:32 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
22:01:32 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
22:01:32 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 00000000
22:01:32 lte,packet,raw lte1 mbim: 05000000 05000000 00000000 ffffffff
22:01:32 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:32 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:32 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:32 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:32 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:32 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:32 lte,async,raw lte1: rcvd LTE service cell:
22:01:32 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:32 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:32 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:32 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:32 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:35 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:35 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:35 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:35 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:35 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:35 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:35 lte,async,raw lte1: rcvd LTE service cell:
22:01:35 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:35 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:35 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:35 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:35 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:38 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:38 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:38 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:38 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:38 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:38 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:38 lte,async,raw lte1: rcvd LTE service cell:
22:01:38 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:38 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:38 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:38 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:38 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
22:01:41 lte,async,raw lte1: sent AT+GTCAINFO?
22:01:41 lte,async,raw lte1: rcvd +GTCAINFO:
22:01:41 lte,async,raw lte1: rcvd PCC:100,0,0,255,0,0,0,0,0,0,0
22:01:41 lte,async,raw lte1: rcvd SCC1:1,0,100,0,0,255,0,0,0,0,0,0,0
22:01:41 lte,async,raw lte1: sent AT+GTCCINFO?
22:01:41 lte,async,raw lte1: rcvd +GTCCINFO:
22:01:41 lte,async,raw lte1: rcvd LTE service cell:
22:01:41 lte,async,raw lte1: rcvd 1,4,311,480,0,A1F713,0,0,0,255,0,0,0,0
22:01:41 lte,async,raw lte1: rcvd LTE neighbor cell:
22:01:41 lte,async,raw lte1: sent AT+GTANTINFO?
22:01:41 lte,async,raw lte1: rcvd +GTANTINFO: "0",0,0
22:01:41 lte,async,raw lte1: rcvd +GTANTINFO: "1",0,0
