hAP ax S - block diagram?
Is there a block diagram available yet? It is suspicious by its absence :wink:
It's not uncommon for a newly released device that some info is lagging.
As educated guess I think you can take the one from Hex S 2025 and add the wifi part to CPU.
I suspect it will not be that far off.
But then again, there could be a nice surprise where I am totally wrong too.
The block diagram is there now, and @holvoetn is right: itโ€™s basically a Hex S Refresh with WiFi (an MT7976 connected to the CPU by 2 PCIe lanes).
Awesome - cheers folks!
Block diagram for reference: https://cdn.mikrotik.com/web-assets/product_files/E62iUGS-2axD5axT_251132.png
All I know is that triple chain wifi = fasterdownloads
fasteruploads as well. On the device manual page it even says dual chain 5ghz.
"5 GHz 802.11a/n/ac/ax dual-chain."
https://help.mikrotik.com/docs/spaces/UM/pages/348782676/hAP+ax+S#:~:text=5%20GHz%20802.11a/n/ac/ax%20dual-chain.
MikroTik has a tendency to release product information that isnโ€™t always entirely accurate at launch.
Does anyone already have this device? Iโ€™m curious about how well the Mediatek WiFi performs
