I have recently upgraded my home network to 1x hAp Ax3 (ROS7.22 stable, router, Capsman controller) and 2x hAp Ax S (ROS7.23rc4)as caps. Network is generally working, including roaming etc. However, the clients connected to the hAp Ax S keep disconnecting. Upon disconnecting, they will be unable to connect for a few mins and then it works again. Intel AX201 works the worst of all clients, while Pixel 8 works almost perfectly.
Oddly, when I change anything in the Capsman config and provision, all disconnected devices immediately reconnect and work well for a few minutes, until disconnecting again.
Have tried disabling WPA3, disabling FT, disabling FT over DS, avoid DFS channels and upgrading Caps to ROS7.23rc4 from 7.22 stable but nothing helps. Any ideas?
Capsman config:
# 2026-05-24 22:57:36 by RouterOS 7.22
# software id = R7LG-EWRF
# model = C53UiG+5HPaxD2HPaxD
# serial number = xxx
add admin-mac=xxx auto-mac=no comment=defconf name=bridge
/interface wireguard
add listen-port=13231 mtu=1420 name=wg1
/interface ethernet switch
set 0 cpu-flow-control=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi configuration
add disabled=no name=cfg-home security.authentication-types=wpa2-psk,wpa3-psk \
.ft=yes .ft-mobility-domain=0x1 .ft-over-ds=yes ssid=MikroTik
/interface wifi
set [ find default-name=wifi1 ] configuration=cfg-home configuration.mode=ap \
disabled=no
set [ find default-name=wifi2 ] configuration=cfg-home configuration.mode=ap \
disabled=no
/interface wifi datapath
add bridge=bridge disabled=no name=dp-home
add address-pool=default-dhcp interface=bridge name=defconf
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys \
source="\r\
\n :foreach iface in=[/interface/wifi find where (configuration.mode=\"a\
p\" && disabled=no)] do={\r\
\n /interface/wifi wps-push-button \$iface;}\r\
\n "
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add comment=defconf interface=ether5 list=WAN
add interface=wg1 list=LAN
/interface wifi cap
set caps-man-addresses=127.0.0.1 discovery-interfaces=lo enabled=yes
/interface wifi capsman
set enabled=yes interfaces=bridge
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=cfg-home
/interface wireguard peers
add allowed-address=192.168.89.3/32 client-address=192.168.89.3/32 \
client-dns=192.168.88.1 client-endpoint=xxx \
endpoint-port=13231 interface=wg1 name=Thinkpad public-key=\ xxx
add allowed-address=192.168.89.4/32 client-address=192.168.88.4/32 \
interface=wg1 name=Pixel public-key=\xx
add allowed-address=192.168.89.5/32 client-address=192.168.89.5/32 \
endpoint-port=13231 interface=wg1 name="Laptop" public-key=\xxx
192.168.88.0
add address=192.168.89.1/24 interface=wg1 network=192.168.89.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf default-route-tables=main interface=ether5 name=ether1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add address=192.168.88.1 name=router.eymatt type=A
established,related,untracked
invalid
add action=accept chain=input comment="Allow WireGuard" dst-port=13231 \
in-interface=ether5 protocol=udp
add action=accept chain=forward comment="Allow WG to Internet" in-interface=\
wg1 out-interface=ether5
wg1 out-interface=bridge
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="WG clients NAT" out-interface=\
ether5 src-address=192.168.89.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Zurich
/system identity
set name=xxx
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
Cap config:
2026-05-24 23:06:10 by RouterOS 7.23rc4
software id = E9C8-QU6N
model = E62iUGS-2axD5axT
serial number = xxx
add admin-mac=xxx auto-mac=no comment=defconf name=bridgeLocal
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
/interface wifi
managed by CAPsMAN xxx%bridgeLocal, traffic processing on CAP
mode: AP, SSID: xxx, channel: 2472/ax/eC
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap
datapath=capdp disabled=no name=xxx
mode: AP, SSID: xxx, channel: 5320/ax/eeeeeeeC/DI
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
add bridge=bridgeLocal comment=defconf interface=ether5
add bridge=bridgeLocal comment=defconf interface=sfp1
/interface wifi cap
set discovery-interfaces=bridgeLocal enabled=yes slaves-datapath=capdp
/ip dhcp-client
add comment=defconf interface=bridgeLocal name=client1
/system clock
/system identity
set name=xxx
