Hi Community,
Being relatively new to the mikrotik world, I have trouble understanding if I got some faulty device or am just too stupid for a good configuration.
There seems to be sth. strange going on with one of my hAP ax S access points:
- The wifi interface names of the default config seem to be different (wifi1 = 5GHz, wifi2 = 2GHz).
- Some clients refuse to connect to that particular device, or prefer APs with much weaker signal. Logs show a “handshake timeout”
In total I got three hAP ax S, and wonder if it is normal that sometimes default interface names are different, or if I got some type of faulty device. Two out of three work fine with the config, one of them is a troublemaker…
Any opinion/ direction about what may be wrong is much appreciated.
Thanks already,
Chris
Situation:
- **Setup: **
RB5009 with CAPsMAN, 3 hAP ax S as access points, one per floor (reinforced concrete walls in my house), wired connection to router. - RouterOS/ Firmware version: V7.22.2
- **Configuration: **
Same config on all APs (reset to factory, removed default config, used the same script for configuration), wifi part below - Unexpected behavior:
- Some clients completely refuse to connect to the AP in question (2VAX),
- other clients do connect when nothing else is around, but prefer APs with much lower signal,
- other clients drop after some time and need reconnect, including password.
- What I tried so far for remediation without success:
- Rule out interference
Switched off all but one interface 2VAX (2GHz), the most stubborn clients don’t connect at all, others will connect. As soon as another (weaker) AP from a different floor comes up, connection is transferred - Switch off FT
- Switch off WPA3
This gave trouble in combination with FT - reduce TX power
- manually configure channels, to prevent overlap
- Reinstall from scratch
logs, config, details,…
Wireless debug log from CAPsMAN (2G_2VAX gives trouble, 2G_1VAX connects well, client stubbornly refuses to connect, even if there is no other signal around)
2026-04-29 22:29:55 wireless,debug AA:AA:AA:AA:AA:AA@2G_2VAX(SSID) associated, signal strength -60
2026-04-29 22:29:56 wireless,debug AA:AA:AA:AA:AA:AA@2G_2VAX(SSID) reauthenticating
2026-04-29 22:29:56 wireless,debug AA:AA:AA:AA:AA:AA@2G_2VAX(SSID) associated, but was associated already
2026-04-29 22:29:58 wireless,debug AA:AA:AA:AA:AA:AA@2G_1VAX(SSID) associated, signal strength -73
2026-04-29 22:29:58 wireless,info AA:AA:AA:AA:AA:AA@2G_1VAX(SSID) connected, signal strength -73
2026-04-29 22:30:03 wireless,debug AA:AA:AA:AA:AA:AA@2G_2VAX(SSID) disassociated, key handshake timeout, signal strength -59/interface/wifi/radio/print detail (on 2VAX)
Flags: L - LOCAL
0 L radio-mac=AA:AA:AA:AA:AA:AA tx-chains=0,1 rx-chains=0,1 bands=2ghz-g:20mhz,2ghz-n:20mhz,20/40mhz,2ghz-ax:20mhz,20/40mhz ciphers=tkip,ccmp,gcmp,ccmp-256,gcmp-256,cmac,gmac,cmac-256,gmac-256 min-antenna-gain=6
countries=all 2g-channels=2412,2417,2422,2427,2432,2437,2442,2447,2452,2457,2462,2467,2472 max-vlans=4095 max-interfaces=16 max-station-interfaces=19 max-peers=120 hw-type="mt7916"
hw-caps=sniffer,qos-classifier-dscp,channel-switch,6 interface=wifi21 L radio-mac=BB:BB:BB:BB:BB:BB tx-chains=0,1,2 rx-chains=0,1,2 bands=5ghz-a:20mhz,5ghz-n:20mhz,20/40mhz,5ghz-ac:20mhz,20/40mhz,20/40/80mhz,20/40/80/160mhz,5ghz-ax:20mhz,20/40mhz,20/40/80mhz,20/40/80/160mhz
ciphers=tkip,ccmp,gcmp,ccmp-256,gcmp-256,cmac,gmac,cmac-256,gmac-256 min-antenna-gain=6 countries=all
5g-channels=5180,5200,5220,5240,5260,5280,5300,5320,5340,5360,5380,5400,5420,5440,5460,5480,5500,5520,5540,5560,5580,5600,5620,5640,5660,5680,5700,5720,5745,5765,5785,5805,5825,5845,5865,5885,4920,4940,4960,
4980
max-vlans=4095 max-interfaces=16 max-station-interfaces=19 max-peers=120 hw-type="mt7916" hw-caps=sniffer,qos-classifier-dscp,channel-switch,6 interface=wifi1
/interface/wifi/configuration/print detail (on CAPsMAN)
name="2G" country=Netherlands installation=indoor ssid="SSID" mode=ap station-roaming=no
security.authentication-types=wpa2-psk .encryption=ccmp,gcmp,ccmp-256,gcmp-256 .wps=disable
datapath=datapath_vlan20
datapath.bridge=bridge .client-isolation=yes .vlan-id=20
channel=2GHZ::AUTO
channel.frequency=2412,2437,2462 .band=2ghz-ax .width=20mhz
