Testing again...
First made sure Hex S also had the same version as hAP AX S (it was still on 7.22b3, my bad).
Test clients:
PC = W11 - Intel AX201 160MHz
S25
Setup: RB5009 (iperf container) - L009 (managed switch) - Hex S - hAP AX S on ether 1
2437 and 40Mhz width
5260 and 80MHz width.
Both 2GHz and 5GHz connect now, on S25 and PC.
Iperf testing doesn't bring me a lot more then about 360-370Mbps using S25, CPU stays below 50%.
(on PC it's even lower
Moved uplink on AX S to ether2
S25 connected to 5GHz
Iperf moves a bit closer towards 400 but rarely over. CPU mostly stays below 40% here.
Coincidence ? With only 1 ether port connected there should be no difference in performance if that port is ether1 or ether2. Wifi interfaces are never offloaded so basically the CPU load should stay the same, I think ?
Moving 5GHz to 5745, channel 160MHz.
No connection possible. Not on PC, not on S25, not even on 2GHz anymore ??
Checking interface wifi radio reg-info for Belgium, I can understand why.
It only goes to 5725-5872 and normally block for 160Mhz is from 5475 to 5895 (which is not included)
/interface/wifi/radio> reg-info country=Belgium number=1
ranges: 5150-5250/23/indoor
5250-5350/20/indoor/dfs
5470-5725/26/dfs
5725-5875/13
Even lowering width to 80Mhz, doesn't make it usable.
Going back to 5180/160 on 5Ghz.
Can't connect both S25 nor PC
Lowering width to 80Mhz, same. No connection possible.
Rebooting everything ...
After reboot, still can't connect S25 nor PC to 2GHz.
5GHz does work, for a moment, and then gets kicked out.
After some retries, it connects again.
This product is far from stable with current ROS versions !
