hAP ax2 5GHz wifi not showing for phone
Just bought hAP ax2, changed the subnet and WiFi SSID and password. 2GHz and 5Ghz names are different. Now I can’t figure out why my phone(Galaxy A52s https://www.gsmarena.com/samsung_galaxy_a52s_5g-11039.php) can’t see 5Ghz, but my laptop(Hp Elitebook 845 G7) can. Both have WiFi ax support.
Help.rsc (5.32 KB)
Since you did not specify the frequency, it’s auto.
And AX2/AX3 tend to favor high ranges when left to auto, so it seems.
Check which frequency is being used by AX2.
Next check if A52 can use that frequency. Especially when the frequency is in the higher range (UNII-3) it might become a problem.
As a test, set the frequency to the lower or mid 5GHz range (5180-5580). Does your A52 see AX2 then ?
