HAP AX2 as a bridge (giving out IP-s from parent)
I would like to get my new HAP AX2 into mode where it will give out IP addresses from the parent DHCP server (ATL LTE18 kit) to it’s Wifi connected and wired clients. So it would act as a "bridge"I guess. In my old router, I could choose between Router/Bridge mode -here I can’t somehow.
Would it be possible to achieve with some conf?
Or I got a wrong product for my need with its limitations?
My planned network [ATL LTE18 kit] ----- [HAP AX2] (garage, wifi and wired clients) ------ [Poe Switch] (house) ----- [AP]
Why not use ax2 as main router ? And put ATL in LTE pass mode ?
It’s possible to do what you want, you just use ax2 as simple switch/AP. There was tutorial by @anav here but i think it’s taken down.
Basically you need to remove default configuration so you have blank device, add all ports to a single bridge (including wireless interfaces), enable dhcp client on bridge.
Good practice is to reserve one port for off bridge mgmt so you don’t lock yourself out of the device.
Thanks , I will give it a try!
If I don’t leave one port for management, I could probably still connect with WinBox?
You can BUT there is a good chance you will lock yourself out if you make a mistake.
Connect via MAC address because when you remove default configuration there will not be any IP address to connect to.
I would stick to gigabytes plan to use the router as the proper router and the LTE devices strictly as an input WAN device.
However in terms of what you want is basically the AX as an AP/Switch.
highly recommend taking ether5 OFF the bridge for a separate and SAFE way to config the device!!
PS. this is a NON-capsman configuration, KISS !!!
PSS. this is a no vlan configuration and the base subnet is 192.168.88.0
add ingress-filtering=no name=bridgeax vlan-filtering=no
set [ find default-name=ether5 ] name=OffBridge5
add name=TRUSTED
/interface wireless
add bridge=bridgeax  interface=ether2
add bridge=bridgeax  interface=ether3
add bridge=bridgeax  interface=ether4
add bridge=bridgeax  interface=WLAN1-HOME comment=5GHz WIFI
add bridge=bridgeax  interface=WLAN2-HOME comment=2GHz WIFI
add bridge=bridgeax  interface=WLAN-MEDIA  comment="virtual WLAN master is WLAN2-HOME"
add bridge=bridgeax  interface=WLAN-GUEST comment="virtual WLAN master is WLAN1-HOME"
set discover-interface-list=TRUSTED
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=NONE
add interface=bridgeax list=TRUSTED
add interface=OffBridge5 list=TRUSTED
add address=192.168.88.X/24 interface=bridgeax=192.168.88.0
add address=192.168.55.1/30 interface=OffBridge5 network=192.168.55.0
set servers=192.168.88.1
add  dst-address=0.0.0.0/0 gateway=192.168.88.1 routing-table=main
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
NOW if you lets say had three vlans coming from LTE ( the smart way to separate media deviced and guest from being able to access home users/devices )
Assuming on LTE 3 vlans created are:
vlan5-HOME - 192.168.88.0/24
vlan10-MEDIA
vlan20-GUEST
interface bridge
add ingress-filtering=no name=bridgeax vlan-filtering=yes
/interface vlan
add interface=bridgeax name=vlan5-HOME  vlan-id=5
add name=TRUSTED
/interface wireless
add bridge=bridgeax  ingress-filtering=yes frame-types=admit-priority-and-untagged interface=ether2 pvid=5
add bridge=bridgeax  ingress-filtering=yes frame-types=admit-priority-and-untagged interface=ether3 pvid=5
add bridge=bridgeax  ingress-filtering=yes frame-types=admit-priority-and-untagged interface=ether4 pvid=5
add bridge=bridgeax  ingress-filtering=yes frame-types=admit-priority-and-untagged interface=WLAN1-HOME pvid=5
add bridge=bridgeax  ingress-filtering=yes frame-types=admit-priority-and-untagged interface=WLAN2-HOME pvid=5
add bridge=bridgeax  ingress-filtering=yes frame-types=admit-priority-and-untagged interface=WLAN-MEDIA  pvid=10
add bridge=bridgeax  ingress-filtering=yes frame-types=admit-priority-and-untagged interface=WLAN-GUEST pvid=20
/ip bridge vlan
add bridge=bridgeax  tagged=ether1,bridgeax  untagged=ether2,ether3,ether4,WLAN1-HOME,WLAN2-HOME  vlan-ids=5
add bridge=bridgeax  tagged=ether1  untagged=WLAN-MEDIA  vlan-ids=10
add bridge=bridgeax  tagged=ether1  untagged=WLAN-GUEST vlan-ids=20
/ipv6 settings
add interface=vlan5-HOME list=TRUSTED
add address=192.168.88.X/24 interface=vlan5-HOME=192.168.88.0
/tool mac-server
Thanks for the great tips @gigabyte091 and @anav - indeed handing wireguard tunnels and DNS and DHCP and everything else was maybe too much for this LTE18 board. After making it to serve only LTE modem functionality with the passthrough and moving everything else to HAP ax² the network is much more stable. Still figuring out my Wireguard based tunneling and routing between homes, but this is fun part and gives an opportunity to learn.
It looks like the HAP ax² does not have Back to Home functionality working well. It just gives a wrong hostname to the mobile app ( *.vpn.mynetname.net instead of *.sn.mynetname.net)
