I’d like to use an hAP ax2 as an AP like I use a hAP ac. The hAP ac has an option WISP AP in the Quick Set menu that makes it very easy. But hAP ax2 has no such options. I’ve been trying to do it “manually” (removing dhcp server, adding ETH1 port to the bridge, removing address 192.168.88.1.24,…..) with mixed strange results……
Is this possible at all?
It's pretty straight forward, reset the device and completely wipe it's configuration so you can start from scratch. Login with winbox using Mac address, do not use the quickest function it won't do what you want. Create a bridge and add all your ports to it, ethernet and WiFi. You can add a DHCP client to the bridge so it gets an IP address from the network or you can set a fixed IP manually just make sure it's outside of the DHCP range or you'll cause issues. Then setup your WiFi 2.4 & 5ghz. Job done.
Basic example……… this one assumes you have a base/management or at least trusted home vlan.
We use ether1 as an emergency access or safe place to config device, even if the bridge has some hiccups. Just plug laptop into ether1, change ipv4 settings to 192.168.75.2 and with username and password you should access the device. Besides trusted vlan 05, the upstream device ( managed switch or router is sending two other vlans to the device vlan30 guest and vlan40 media.
The problem is I don’t have a windows computer. I was resigned to install wine and do it with winbox, which I never use, but I noticed mikrotik has versions for linux and macos now
I will give it a try with winbox. Tx.
