hAP ax2 cannot create a working guest network from mobile app
Cannot create a working guest network from mobile app on hAP ax2, I can do it on my hAP ax3 but not on my ax2 Are there any known issues or limitations on ax2?
I have also tried to create two ssids on 2.4GHz and 5GHz but no difference.
There should be no relevant limitations, in the same RoS version. I use both products.
Perhaps you could put up your exported configuration, any private stuff concealed. In fact, do it for the ax3 as well for comparison.
Good suggestions will do, I'm new with Mikrotik so wonder how I do a read out.
Instructions here:
Forum rules - #5 by gigabyte091
