Trying to put hAP ax2 into caps mode but it would not go in.
Upgraded to stable 7.8 and it lost Wireless interfaces with Critical Error script interupped
Installed other packages but wireless interfaces not coming back.
Not to mension default passwords that were put in caused some back and forth.
If someone can help with caps mode. Capsman is older version running 7.7.
If you install the wifiwav2 package, wireless interfaces should be available again. Think that would be the first step.
If that is not working (and you have more goovy stuff), you might want to consider performing a netinstall.
You have to configure CAP manually, currently, there is no CAPs mode available by reset button.
Keep in mind that WifiWave2 CAPsMAN and its CAPs are not interoperable with legacy CAPsMAN and its CAPs.
WifiWave2 CAPsMAN uses the same menu as WifiWave2 interfaces, GUI support for it is available since 7.8. https://help.mikrotik.com/docs/display/ROS/WifiWave2#WifiWave2-WifiWave2CAPsMAN
I’m not sure this is correct. My understanding is that wifiwave2 capsman cannot control local devices (127.0.0.1) and you simply have an AP and one single capsman controlled device. During my testing this made transitions far from seamless compared to a separate capsman controller and caps: http://forum.mikrotik.com/t/hap-ax3-wifiwave2-capsman/163543/1
