Willi
December 25, 2023, 1:39pm
1
Hi, I managed to set up a MT installation with a hap ax2 as router and two hap ax2 devices as access points. The wireless is up and running on all 6 radios. I discovered that devices trying to connect to the wireless of the router itselve are disconnected soon after their connection. Clients connecting to one of the AP’s are not suffering from this behauviour. Logs are not giving any additional info (see attached image)
Anyone any idea what is causing this? The configuration on the radio’s of the router is the same as on the AP’s.
akakua
December 26, 2023, 12:20am
2
try set “disabled” to “management protection”
Willi
December 26, 2023, 3:42pm
3
I tried but no effect. If I look to the registration table, the clients that try to connect stay for exactly 20 seconds with Tx rate at 1 Mbps and then disconnect. Looks like a timer was implemented somehow. Any other ideas?
Your config is a small problem. Clients disconnect because they don’t get an IP address.
http://forum.mikrotik.com/t/hap-ax-as-cap-not-reachable-via-winbox-ip/172219/1
Santi70
December 27, 2023, 12:47pm
5
Something similar happens to me, I don’t understand why it disconnects, it only happens with the iPhone 14 pro max.
Here the configuration
# 2023-12-27 13:33:25 by RouterOS 7.13
# software id = G48Y-1U35
# model = RBD52G-5HacD2HnD
# serial number = XXXXXXXXX
add admin-mac=2C:C8:1B:C9:12:CB arp=reply-only auto-mac=no name=bridge
/interface wireguard
add comment=back-to-home-vpn listen-port=58216 mtu=1420 name=back-to-home-vpn
/interface vlan
add interface=ether1 name=vlan20 vlan-id=20
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan20 name=pppoe-out1 user=968587466@xxxx
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi channel
add band=2ghz-n disabled=no frequency=2412 name=channel01 width=20mhz
add band=5ghz-ac disabled=no frequency=5680,5170 name=channel136 width=20/40mhz
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no management-protection=allowed name=sec1 wps=disable
/interface wifi configuration
add channel=channel01 country=Spain disabled=no mode=ap name=cfg01 security=sec1 security.ft=yes .ft-over-ds=yes ssid=Nely
add channel=channel136 country=Spain disabled=no mode=ap name=cfg136 security=sec1 security.ft=yes .ft-over-ds=yes ssid=Nely
/interface wifi
set [ find default-name=wifi1 ] configuration=cfg01 configuration.mode=ap .tx-power=9 disabled=no
set [ find default-name=wifi2 ] configuration=cfg136 configuration.mode=ap .tx-power=16 disabled=no security.connect-priority=0
/ip hotspot profile
add name=default-dhcp ranges=192.168.52.100-192.168.52.254
add add-arp=yes address-pool=default-dhcp interface=bridge lease-time=8h name=LAN
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add interface=bridge list=LAN
add address=192.168.52.1/24 comment=LAN interface=bridge network=192.168.52.0
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes
/ip dhcp-server lease
add address=192.168.52.106 client-id=1:3c:6a:a7:44:80:36 mac-address=3C:6A:A7:44:80:36 server=LAN
add address=192.168.52.105 client-id=1:8e:da:61:c1:e7:d0 mac-address=8E:DA:61:C1:E7:D0 server=LAN
add address=192.168.52.98 client-id=1:80:fa:5b:5f:54:91 mac-address=80:FA:5B:5F:54:91 server=LAN
add address=192.168.52.104 mac-address=90:0C:C8:EA:56:49 server=LAN
add address=192.168.52.100 mac-address=1C:3B:F3:8D:FE:B6 server=LAN
add address=192.168.52.101 client-id=1:a:cf:fd:85:cc:51 comment=IphoneNely mac-address=0A:CF:FD:85:CC:51 server=LAN
add address=192.168.52.0/24 comment=defconf dns-server=192.168.52.1 gateway=192.168.52.1 ntp-server=192.168.52.1
set allow-remote-requests=yes servers=8.8.8.8,9.9.9.9,2620:fe::fe,2001:4860:4860::8844
/ip dns static
add address=192.168.52.1 name=nrouter.lan
add cname="nrouter.lan " comment="nrouter.lan " name=hapac2.lan type=CNAME
add action=accept chain=input comment=" accept established,related,untracked" connection-state=established,related,untracked
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.52.98/32,
set ssh disabled=yes
set api disabled=yes
set winbox address=\
192.168.52.98/32,
set api-ssl disabled=yes
/ipv6 address
add address=::1 from-pool=pool6 interface=bridge
/ipv6 dhcp-client
add add-default-route=yes interface=pppoe-out1 pool-name=pool6 rapid-commit=no request=address,prefix
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" log-prefix=ipv6 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 nd
set [ find default=yes ] interface=bridge other-configuration=yes
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=hap_ac2
ivicask
December 27, 2023, 12:53pm
6
I just notice that i have same problem with one client after updating everything to new qualcomm drivers and new capsman, note that all other devices connect fine on all CAPs
Not sure even which device it is, client didint complain back yet, might be some smart crap device.
mkx
December 27, 2023, 2:06pm
7
One user in another thread managed to solve a similar problem with apple device by setting management-protection=disabled . Note that WPA2 allows management frame protection but WPA3 requires it, so by setting this to disabled you may loose WPA3 (but since it’s required for WPA3, ROS may ignore this setting for WPA3 as well).
But according to description in wifi manual it’s best to leave it unset … which then allows ROS to select best value based on used authentication type. If that pleases station devices …
Santi70
December 27, 2023, 8:42pm
8
Exactly, that was the solution, now everything works fine. Thank you
Edited:
After a calm night, the same thing happened again, now I updated version 14beta4 and for now everything is calm, I hope it has been fixed although I have not seen anything in changes made by version 14 that speaks to this.
Thank you
and the errors come back, I don’t know what to try anymore
What about interference? Seems you are using the 2.4GHz band which might be subject to a lot of interference.
Can you share your config:
/export file=anynameyoulike
Remove serial and any other private information and post the about in between code tags by use of the </> button.
Thanks, wifi2 is the 5G channel, it is an ac2, there is no one broadcasting in that band (channel 136)
# 2024-01-07 18:23:33 by RouterOS 7.14beta4
# software id = XXX
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec1 wps=disable
/interface wifi
Can you pick just one frequency for the 5GHz radio and see if that helps?
What is the setting of Group Encryption? I selected CCMP.
Only difference I see in comparison to my config is that I set FT on the security tab (Winbox) instead of on the configuration part. But that doesn’t make a difference.
The two frequencies are in case a radar signal appears, I have another frequency option, otherwise it falls and doesn’t pick me up anymore, it already has.
The default encryption setting is CCMP
mkx
January 8, 2024, 8:30pm
14
5170 is not a standard wifi channel center frequency, 5180 is. Some wireless clients hate non-standard frequency channels, so both center frequency and channel layout have to conform to standard channel list .
Also some clients like to have “control channel lowest” channel layout (e.g. 20/40mhz-Ce) and in this case 5680 is not right frequency either, it should be 5660 (your setting of “20/40mhz” with frequency 5680 would turn out to be “eC” if MT sticks to standard 40MHz channel layout).
Thanks, noted the changes, I’ll fine-tune them to see if it doesn’t cause more problems.
# 2024-01-09 15:01:07 by RouterOS 7.14beta4
# software id = XXXX
add band=5ghz-ac disabled=no frequency=5660,5180 name=channel132_36 width=20/40mhz
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=sec1 wps=disable
add channel=channel01 country=Spain disabled=no mode=ap name=cfg01 security=sec1 ssid=Nely
add channel=channel132_36 country=Spain disabled=no mode=ap name=cfg132_36 security=sec1 ssid=Nely
/interface wifi
set [ find default-name=wifi2 ] configuration=cfg132_36 configuration.mode=ap .tx-power=16 disabled=no
Aside but some Wi-Fi chipsets (e.g. some Realtek) sometimes struggle with channel 149 (5745) and above. Sometimes you can disable 801.11d and those channels will work. Something to do with not detecting the country correctly and not realising those channels are allowed. However, on Android, I think you’re stuck so on my cheap Android tablet, I can’t use Wi-Fi 5 if it’s using 149 or above.
Santi70
January 22, 2024, 9:44pm
17
After the stability in 7.14beta4 when updating to 7.14beta7 without going through beta6, the disconnections began again, now even on Android phones that never gave problems before.
