hAp ax2 does not 5GHz does not works
Has anybody faced an issue when brand new out of the box ax2 does not shows 5GHz networks?
I set it up as AP using caps map. In inbox everything looks grate but none of devices can see 5G network. 2G is totally ok.
It doesn’t even shows 5GHz right after full reset with default configuration. It shows default Mikrotik-XXXXX network for 2GHz but nothing for 5GHz. And again in WinBox no issues so far.
Updating packages up to 7.12rc5 doesn’t changes the situation. :confused:
When starting from default config, can you use scan for that radio to see what other aps are around ?
If that works, the radio is ok.
Already tried netinstall ?
