HAP AX2 PoE out
Hello!
Dont understand how can I connect PoE device and use PoE-out on first port and at the same time connect to internet via cable.
As I understand PoE available only on 1st port.
My 1st port is WAN - Internet from my provider via ethernet cable.
At the same time i need to connect to HAP AX2 my door station via ethernet cable with PoE supply.
Іs it possible to reassign PoE or WAN to another port or there is another solution.
Would be gratefull for prompt suggestions.
Quite easy to change ( WAN, not PoE out).
Assume WAN becomes ether2.
Connect to ether port 3, 4 or 5.
Winbox using MAC address
Remove ether 2 from bridge
Change dhcp client from ether 1 to ether 2
Add ether 1 to bridge
Change interface list for WAN to ether2
Check if LAN is bridge. If not, add ether1 to LAN.
And that should be it, I think.
