Hi, I’m AndyV.
I recently purchased a HAP AX2 (update to 7.14.3 + qcom done) to combine with my home modem to create a personal LAN / WAN.
I tried both with a “quick set” configuration and with a hand-made configuration, but I encounter the following problem: some devices are unable to reach the speed that they can achieve if connected to the home modem.
The speed between modem and AX2 via ethernet is 1Gbps (as it should be).
The home modem is a “Vodafone WIFI 6 Station” equipped with a 6E wifi card.
The specifications of the HAP AX2 are known.
I tested the following devices and got the following results (download/upload):
iPhone15 → Modem = about 700/550 Mbps
iPhone15 → AX2 = about 200/400 Mbps
iPhone15pro → Modem = about 700/550 Mbps
iPhone15pro → AX2 = about 700/550 Mbps
pc with RTL8852AE → Modem = about 700/550 Mbps
pc with RTL8852AE → AX2 = about 300/400 Mbps
pc with Intel AX200 → Modem = about 700/550 Mbps
pc with Intel AX200 → AX2 = about 300/400 Mbps
iPad5gen → Modem = about 550/400 Mbps
iPad5gen → AX2 = about 150/300 Mbps
I attach the hand-made configuration currently loaded on the AX2.
Can anyone explain why some devices manage to reach the correct speed, while others fail?
I have also done tests with other devices (not written above) that manage to reach the correct speed.
I don’t think it’s something related to the devices’ wifi cards, because connected to the modem they can perform correctly, while connected to the AX2 they don’t.
I’ve tried to provide as much data as I can.
Any help will be considered invaluable, I’m literally going crazy…
Thank you all!
add name="LAN - Bridge"
set [ find default-name=ether1 ] name="ether1 - WAN"
add name=dhcp_pool1 ranges=10.1.1.100-10.1.1.200
add address-pool=dhcp_pool1 interface="LAN - Bridge" lease-time=1d name="LAN - DHCP"
add bridge="LAN - Bridge" interface=ether2
add bridge="LAN - Bridge" interface=ether3
add bridge="LAN - Bridge" interface=ether4
add bridge="LAN - Bridge" interface=ether5
add bridge="LAN - Bridge" interface=wifi1
add bridge="LAN - Bridge" interface=wifi2
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=disabled .width=20/40/80mhz configuration.mode=ap .ssid=WIFItest disabled=no security.authentication-types=wpa2-psk,wpa3-psk security.passphrase="A123456a!" .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=disabled .width=20/40mhz configuration.mode=ap .ssid=WIFItest disabled=no security.authentication-types=wpa2-psk,wpa3-psk security.passphrase="A123456a!" .ft=yes .ft-over-ds=yes
add address=10.1.1.254/24 interface="LAN - Bridge" network=10.1.1.0
add address=192.168.1.50/24 interface="ether1 - WAN" network=192.168.1.0
add address=10.1.1.0/24 dns-server=8.8.8.8 gateway=10.1.1.254
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-table=main suppress-hw-offload=no
/system clock
set time-zone-name=Europe/Rome
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
# Reboot the router to apply updates
/system reboot
