hAP ax2 - WiFi station mode choosing far away APs to connect (which fails to connect)
I’m running my router at dorms and we have multiple APs for connection to eduroam.
I successfully set it up to connect, but sometimes it chooses some far away AP and loops connecting to it (without success of course) instead of choosing the closest.
Is there some way to make it choose the closest or just define the best one by MAC address?
how did you make your station to connect to eduroam?
can you share your configuration?
thanks
